If one transistor in a circuit (say common source with active load) operate at the strong inversion region, should the rest of the transistor also operate on that same region? Or will it depend?
    \$\begingroup\$ I like to make logic inverters. The other transistor should be in cutoff. Perhaps you need to add more information to your question. \$\endgroup\$ – Elliot Alderson Nov 19 '18 at 16:17
No, you can't assume all the FETs in a circuit operate in the same mode.
Each FET operates in the mode determined by the potentials at its terminals.
In a simple analog amplifier it's likely that the designer arranged that many of the FETs will normally be operating in the saturation region. But in a CMOS digital gate it's likely that the designer would arrange for some devices to operate in the triode or saturation region while others are in cut-off.
