The product page for the LM833N on ti.com lists a typical output current of 40mA. Such an output current in the tens of milliamps is a typical output current maximum for most general purpose op amps. Note that this is a typical value so don't assume every LM833N can supply 40mA. There's no specification on the minimum output current the LM833N can supply but as long as its load doesn't draw more than ~20mA you should be fine.
The input impedance of the LM833N isn't specified (and I don't see it on the product page, either) but the datasheet does say that the input bias current is 1000nA maximum. This is the information you need to set the voltage divider resistors \$R_1\$ and \$R_2\$ which bias the LM833N's non-inverting input to \$V_{\text{DD}}/2\$. In order to make sure that the voltage divider produces the correct voltage at its output you should make sure that the bias current through those resistors is ten times the input bias current on the LM833N -- i.e. 10uA or more. You don't want that bias current to be much higher than that, though, otherwise it will draw more power than necessary. \$237\Omega\$ is a small value for that purpose -- with \$V_{\text{DD}} = 5\text {V}\$ the bias current is approximately 10mA. You can set \$R_1\$ and \$R_2\$ a thousand times higher (i.e. \$237\text{k}\Omega\$) to achieve a 10uA bias current.
Regarding the filters at the output of the LM833N you might want to use active filters and/or buffer the passive filters to simplify the design. With those passive filters loading each other like you've shown you'll have to take into account the impedances of each passive filter. If you put an op amp buffer in between each passive filter (or use an op amp as part of the filter to make it an active filter) then you gain the high input impedance and low output impedance of the op amps and you can design the filters independently. The tradeoff is that you'll need more op amps (though you might have an unused op amp anyway since you're only showing one LM833N op amp but the LM833N is a dual op amp package).
Another thing you might consider is buffering the output of the voltage divider formed by \$R_1\$ and \$R_2\$ since you need a 2.5V bias voltage for both of the op amps (and any additional op amps used in the filters). With a buffer for this voltage divider you can connect the 2.5V bias voltage directly to the non-inverting inputs of the op amps rather than using \$R_{11}\$ and \$R_{12}\$ to produce another 2.5V bias. Instead of using \$R_{11}\$, \$R_{12}\$, and \$C_5\$ as a passive 1st order HPF you can use an active 2nd order HPF and get rid of the passive 1st order HPF formed by \$C_3\$ and \$R_7\$, thus removing a stage from the pre-amplifier. Figure 33 of the LM833N datasheet shows a Butterworth 2nd order HPF you can use, complete with the equations necessary to set the cutoff frequency.
This is what your circuit would look like with a buffered 2.5V reference:
Note that \$C_1\$ is still required to block DC, though it is no longer filtering.
