I have a question about the high side driver VN7016AJ for automotive applications, during ISO pulse1 -150 V will be applied at its VCC pin, I found from the User manual (UM1922) that when -150 V is applied the voltage at different pins of the device but I couldn't quite understand the voltages at (-144 v) at SEn and Faultreset pins
Could someone please explain?
Also I found in the same manual that it says in reverse battery condition, ( pages 18,19 of UM1922) , due to the clamping voltage of internal ESD diodes on logic pins SEn, SEL,IN,Faultreset the voltage is dropping to -10V , I didn't quite exactly what they are taking about , will the diodes clamp any voltage above -10 V to -10V or is it that in the case that they are describing the voltage across the diode be 6v and hence -16+6 = -10V ?
