Please I am just a kid no $8953739857239875 power supplies. Btw I am an inspiring electrical engineer and I'm 10 so I need a bit of help so I don't how do I put this nicely, ahem trip the breaker if you know what I mean
closed as off-topic by AndrejaKo, duskwuff, Hearth, Dave Tweed Nov 21 '18 at 14:39
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Hi young man/woman. Welcome to EE.SE. I'd suggest you for your safety to have an adult technician while having fun with these stuff. Electricity is an amazing but dangerous thing. At your early stage you may need somebody to bring the voltage to 5 V DC, where you can have fun and innovate without risking your safety. \$\endgroup\$ – Hazem Nov 21 '18 at 4:36
  • \$\begingroup\$ Hi! Take a look at our list of approved topics. We don't actually like shopping recommendation questions here, and your question, as it looks right now, seems to be looking for a specific product as an answer. \$\endgroup\$ – AndrejaKo Nov 21 '18 at 7:03
  • \$\begingroup\$ For safety, you can use those volt "lantern batteries". No shock hazard. And a large diode (not 1N4148, but 1N4001 style) reduces the voltage to approximately 5.3 volts, good for logic experiments. Have you build a light-controlled LED driver? \$\endgroup\$ – analogsystemsrf Nov 21 '18 at 13:40
First off, I’m in the same boat as you (just 13 myself). By “adjustable power supply” do you mean adjustable voltage, current, or both?
If you want adjustable voltage, you can easily make one using something like an LM317, which is an adjustable voltage regulator.
If you want adjustable current, you can make your own using something as simple as a potentiometer, just check the power dissipation rating.
Building your own is probably the cheapest option, if possible. It’s also fun and a great learning experience (I’ve made an adjustable voltage supply). However, if you need adjustable voltage and current, that can get a bit trickier. If you know how to make one, go for it, but otherwise, here’s a $40 one. Not dirt-cheap, but it’s high quality, will last a while, and the holidays are coming up. Good luck!
  • \$\begingroup\$ I did not even expect a responce thank you for your time and I can't wait to get this and yes I will purchase it THANK YOU \$\endgroup\$ – user205044 Nov 21 '18 at 23:35
  • \$\begingroup\$ @user205044 No problem. If the answer worked, you can mark it as accepted to show that it helped you and to let others know you don't need more responses. \$\endgroup\$ – Kian Kasad Nov 26 '18 at 1:32
