I have an 8 Ω speaker and a Raspberry Pi. To play sound, I can connect the Raspi directly to the speaker, which works, but with very limited volume. I assume this is because of the 3.3 V PWM output by the Raspi which provides up to 20 mA (correct me if I'm wrong).
I therefore decided to test an LM358 OpAmp, which essentially is a voltage multiplier when it operates in closed-loop gain. The Raspi signal is 3.3 V already, so with a 5 V power supply I can at most go to 5 V, corresponding to Vout/Vin = 1/β = 1.5
(therefore R1 = 1 kΩ and R2 = 2 kΩ).
As the LM358 can provide around 20 mA as well, I would expect the loudspeaker to be slightly louder as it is driven with 5 V instead of 3.3 V, and P = U · I
The result is that the loudspeaker is indeed a bit louder, but mostly quite distorted and noisy. So not the expected output.
Why do I get such bad output audio? Shouldn’t the OpAmp just do a linear transformation of the signal?
(I probably lack some basic understanding of how OpAmps and speakers are supposed to be used. If so, I’d be happy to get some hints or references to read.)
Edit – WPM measurements
Since knowing the input is important to this question, here some measurements – the first one shows the normal audio waveform, the second one is recorded at higher frequency which shows how the Raspi constructs the waveform. The signal is ± 1 V in these measurements.
I have also found this paper about biasing which provided a nice explanation of scaling and biasing.
I = U / R
, and with 600 Ω headphones and 15 V I would get a 25 mA current which the LM358 is designed for, but the 8 Ω speaker would require 200 mA? – Biasing: The OpAmp’s Ground? Is the issue that (+) is on ± 1 V and (−) is on 0…x V which breaks the subtraction in the OpAmp? \$\endgroup\$
