While repairing a projector, I broke the flap holding the flat flex cable (FFC) in place. It's the type "flip-lock" and is ZIF (Zero Insertion Force) so without the flap in position, the connector doesn't work.
I've tried to contact some FFC connector manufacturers, but they were not able to help identify the part. Please mind that the only thing I know is that has 84 pins.
I read here and here that my challenge isn't easy, but I'm willing to give a try.
Do you have an idea of which manufacturer might produce such connectors?
Do you have an idea about how to fix it, rather than inserting a spacer under the FFC?
Thanks a lot. I hope to have been enough clear and precise.
