I'm working on a electromagnetic levitation system, consisting of a flat spiral (planar) inductor positioned above a solid copper surface. The planar coil is parallel to the copper surface. (Consider both the coil and the surface to be 100% pure copper, and the surface infinite in area and depth.)
I know how to calculate the inductance of a spiral inductor in free space. In fact, there are a number of calculators online, like this one.
My question is regarding the change of inductance as the coil is brought near the copper surface. My thinking is to consider the copper surface as a "shorted secondary" in a coreless transformer. This would imply that the inductance of the primary is actually the effective leakage inductance based on the system geometry. I suppose that if the primary (the spiral coil), were brought infinitesimally close to the secondary (copper surface), the leakage inductance would be zero. As the coil is moved away from the copper surface, the leakage inductance would increase (up to the full inductance of the coil in free space, at infinite distance from the copper surface below). I think it is probably ok to consider the resistances as negligible (effectively zero).
I am looking for two things:
  1. Guidance on my thinking, confirmation that I'm on the right track, or correction if not.
  2. A formula that I can apply to calculate [the change in] the coil's inductance as it is positioned at different distances to the copper surface. (Typical distances would be on the order of 1 mm for a 25 mm diameter coil, FWIW.)
I realize that I could actually construct this system in some form and measure the inductance, and perhaps even empirically derive a formula. But I'd rather model it first if possible.
  • \$\begingroup\$ Eddy current should be in the model. the lost in near field is high due to eddy current. \$\endgroup\$
    – M KS
    Nov 22, 2018 at 21:05
  • \$\begingroup\$ Eddy current is the whole reason it levitates... the current in the “shorted secondary” is the eddy current, and the inductance of the shorted secondary is assumed to be negligibly low. Am I missing something? \$\endgroup\$ Nov 22, 2018 at 21:09
  • \$\begingroup\$ "shorted secondary" in a coreless transformer" I think this is not true. I am not an expert in this field, But with my knowledge, The transformer helps guide the magnetic flux, but we haven't that, and flux leakage can't be model with a simple model. Zero resistance also is not good for this case in reality. The lost with external copper near WPT coil is high. \$\endgroup\$
    – M KS
    Nov 22, 2018 at 21:32
  • \$\begingroup\$ Think of it this way. If the coil and surface were both superconductive (truly zero resistance), and the coil were paralleled with a lossless capacitor, an alternating current would persist within the system and the coil would hover at a constant distance with no ongoing energy input. \$\endgroup\$ Nov 22, 2018 at 22:24
  • \$\begingroup\$ A coreless transformer can certainly have a shorted secondary. Also, it is not the case that coreless transformers are inherently lossy. Leakage inductance is not loss— it is simply inductance that does not contribute to transfer of energy from the primary to secondary; the energy is simply returned to the primary side. \$\endgroup\$ Nov 22, 2018 at 22:29
You are correct that the inductance would ideally be zero at zero distance.
You can try to model this from first principles using the Biot-Savart law and a simplified geometry, but I think an FEA approach would be faster and probably more accurate. The parasitics (resistance and distributed capacitance) may turn out to be important, depending on what frequency is used. We're measuring displacement using this method, but in our case resistance is zero and the frequency is DC so it's easier.
  • \$\begingroup\$ I'm not sure about driving frequencies yet, but I'm guessing they will be between 10s of kHz and a few MHz. I assume that high frequencies will be able to deliver more levitating power for lower-inductance coils, but of course skin effect will result in higher resistances too... By FEA I assume you mean "Finite Element Analysis"? Do you know of any free packages that can do this? I have used FEMM a little but I'm not sure how to use it to calculate inductance on an element in a system like this. \$\endgroup\$ Nov 22, 2018 at 20:46
    \$\begingroup\$ Here is a decent list. I tried one of these and found it pretty horrific. The simulations we use were done in MathCAD (not by me) from first principles. I'd be inclined to look for a trial version of a commercial program that isn't too limiting. \$\endgroup\$ Nov 22, 2018 at 20:52
    \$\begingroup\$ @KevinH.Patterson You can perfectly model this with the free FEMM tool. Choose „magnetics problem“ and „axisymmetric arrangement“ and the frequency of choice in the project setup. \$\endgroup\$ Nov 23, 2018 at 5:12
    \$\begingroup\$ FEMM can also display the inductance L. You can draw a line from center to the coil and integrate flux density along that line to get total flux which is L*I. I‘m not 100% sure but I think FEMM can also display L directly. \$\endgroup\$ Nov 23, 2018 at 5:23
  • \$\begingroup\$ Thank you for the pointers, @StefanWyss \$\endgroup\$ Aug 1, 2019 at 7:07
