In case of BJT for example, the input characteristics can be described with \$I_B=f(V_{BE})\$ and output characteristics with \$I_C=f(V_{CE})\$.
How can the input and output characteristics be described in case of TTL gates?
  • \$\begingroup\$ \$I_C\$ is a function of both \$V_{CE}\$ and \$I_B\$ in a BJT. More than just \$V_{CE}\$ alone. \$\endgroup\$ – Hearth Nov 23 '18 at 0:30
  • \$\begingroup\$ Yes, that's true. \$\endgroup\$ – A6EE Nov 23 '18 at 0:42
You may model a TTL gate, at least the original low-power devices as
| improve this answer | |
