What is the proper way to connect multiple ethernet devices via MDIO bus?
I know that MDIO (similarly to I2C) is open drain, so I think that I need (just as in I2C) two 1-4, 7 kOhm pull-ups both for MDIO and MDC pins (Do I actually need a pull-up for MDC pin as long as it is a clock output?).
So, my question is the following: if I want to connect 8 devices, what is the proper choice for nominals (1 kOhm or 4.7 kOhm) and is it sufficient to have only one pull-up on the bus or do I need multiple pull-ups (for each IC)? Thanks.
  • \$\begingroup\$ If you want to connect multiple MAC of a processor to each other it is impossible! "The bus only supports a single MAC as the master, and can have up to 32 PHY slaves. " en.wikipedia.org/wiki/Management_Data_Input/Output. If you have one MAC and multiple PHY, one pullup is ok. \$\endgroup\$
    – M KS
    Nov 24, 2018 at 13:08
  • \$\begingroup\$ Thank you for the response!) I want to connect KSZ9477STXI (Ethernet switch IC), five DP83849IFVS (Media Converter IC), DP83620SQ/NOPB (Ethernet PHY IC) and MAX24287ETK+ (SerDes) via single MDIO bus to AM3358 SoC. I'm a little bit confused about MAC/physical addresses of this ICs. DP83849IFVS and DP83620SQ/NOPB appear to have their own physical address (is it MAC address?), besides KSZ9477STXI should have separate MAC address for each port (our maybe I'm wrong and it'll have only single MAC address). So, is it possible to connect all this ICs to AM3358 SoC via MDIO to control their settings? \$\endgroup\$
    – Andy
    Nov 26, 2018 at 6:34
  • \$\begingroup\$ you should have(buy) one MAC address for each physical layer, en.wikipedia.org/wiki/MAC_address. On other hands above your PHY layer, you have a MAC that controls that PHY(en.wikipedia.org/wiki/Medium_access_control). It is better to add your connection diagram. \$\endgroup\$
    – M KS
    Nov 26, 2018 at 7:20
  • \$\begingroup\$ I've added my connection diagram above. \$\endgroup\$
    – Andy
    Nov 26, 2018 at 8:25
  • \$\begingroup\$ It's a complicated design. The whole is ok. What is "MDI"? It should be PHY or Port. each PHY should be set with own address so the MDIO can ping them. I think it is better to design a network with a building block, we have a router, LAN/SFP converter, etc. Breaking the project to a building block makes the project easier. \$\endgroup\$
    – M KS
    Nov 26, 2018 at 10:48
There is no need for multiple pull-ups on MDIO as that would amount to a single pull-up resistance anyway. You would look at MAC or PHY requirements for pull-up resistance and take a value that is compatible with all devices and can provide the timings that are necessary, as bus capacitance will slow down the rising edges.
MDC is an output. Basically, it does not need a pull-up. It might need a pull-down, but again, that is dependent on the MAC and PHY devices you are using.
