So I have a lab practical with the instructions
"Demonstrate an operational amplifier circuit which may consist of one or two op amps with a gain of X (±10%) and a -3dB frequency exceeding Y kHz. The sign of gain can be + or -. "
I understand the operation and build of an amp and this is actually the second time doing this lab as I screwed it up the first time. The first time I was asked to design an amplifier with a gain of 80 with a frequency of around 1kHz. I used a circuit similar to the one depicted below to do this. Obviously my resistor values were different because I required a different gain.
As my understanding, depending on the sign of the gain dictates whether I used the noninverting (-R2/R1) or the inverting equation (1+R2/R1). Using these equations and the desired gain I can choose resistor values that give my desired gain. I also understand that if the desired gain is high enough I will have to cascade op amps. What I'm confused about is designing around the desired -3dB frequency. I guess I would like someone to explain where the -3dB frequency comes in to play in designing an op amp circuit.
