-1
I was hoping to make a gesture+flex sensor controlled glove using an Arduino Lilypad and Raspberry Pi Zero W.
I was wondering how I could connect the two boards to communicate between them?
This is so I can take the flex sensor/accelerometer outputs, play with them in python, then send data over wifi to my pc
Thanks in advance.
Raspberry pi and lillypad both have logic-level UARTs, that's probably the easiest way.
If you're running the lillypad from 5V you'll need a logic level converter for the interface with the 3.3v UART on the raspberry pi
SPI is also an option, but again you'll need a level converter.
Some lillypads have USB if yours is one of them then that'd work too
  • \$\begingroup\$ Thanks Jasen, if I connect the raspberry pi to the Lilypad via USB-MicroUSB, will that supply 5V current? And can they communicate through the USB port? \$\endgroup\$ – 3NiGMa Nov 26 '18 at 5:26
  • \$\begingroup\$ some lillypads have USB if yours is one of them then that'd work too (edit) \$\endgroup\$ – Jasen Nov 27 '18 at 5:38
  • \$\begingroup\$ Thanks, do you know how to grab the input that is coming through the USB port on the RPi? EDIT*I will ask stackoverflow if you consider this a programming question* \$\endgroup\$ – 3NiGMa Nov 27 '18 at 9:48
  • \$\begingroup\$ /dev/ttyUSB0 probably. or ask on "rasp-berry pi". \$\endgroup\$ – Jasen Nov 27 '18 at 9:54
