I have an external speaker which uses one 18650 cell (3.7V). I would like to increase the working hours by adding one more cell of the same type. I have two questions:
  1. Should I add the second cell in parallel with the other cell?
  2. The speaker has a charging LED which powers off when fully charged. Will this still detect full charge if I increase number of cells?
Thanks for help!
  • \$\begingroup\$ Messing with lithium-ion batteries is a good way to start a fire, if you don't know what you're doing. Charge balancing is essential and it's likely your speaker doesn't have the circuitry for it. \$\endgroup\$ – Hearth Nov 25 '18 at 22:00
Connecting an additional (preferably identical) 18650 would theoretically double your capacity, yes. However, there are some safety concerns you need to address first.
  • Does either 18650 have built-in protection? This can be a huge issue if that controller shuts off one battery but the other keeps discharging, due to reasons stated in the next point
  • Are the cells at an equal voltage? If not, connecting them in parallel will induce a massive current from the higher-charged cell. If the difference is too great, this current could flow for a while and overheat the cells
The safer way to do this is to connect two identical unprotected cells at the same voltage in parallel, then hook up your protection circuit to that pair. In your case, I'd bet the protection circuit is somewhere on the PCB for this speaker.
To address point 2, typically charge controllers check that the cell voltage is above a threshold, say 4.2V, at which point it will disconnect (cheap ones will trickle charge after 4.2V but this is supposedly bad for battery health). Your charge controller likely doesn't care about the capacity, so while it may take twice as long to charge, the charge LED should work as intended all the same.
