As we know that for the transistor to operate in the active mode, it should have emitter-base junction as forward bias and collector base junction as reverse bias. So the common-collector configuration should also follow the same rule. Below is a diagram:-
In the above diagram we can see that Emitter base junction is forward-biased since |Vee|>|Vbb|, that's fine. But you can see that the base collector junction is also forward-biased (where it should be reverse-biased if it is in active mode) in both pnp and npn transistors. Please help me here, it has been a confusion for me since 1 month. I really want to understand it here. Please give me a descriptive answer.
