I am working with SIMCom's SIM808 2G+GPS modem and trying to connect it to an SD card. I am following SIMCom hardware design docs, to save some data in SD memory.
The problem is: when I send command "AT+SD2PCM=1" to the module, it returns ERROR message. Can you help me to solve this problem? Thanks.
  • \$\begingroup\$ I have read the relevant documentation.bat i reply error on"AT+SD2PCM=?" command.do you help me? please. \$\endgroup\$ Commented Nov 30, 2018 at 16:08
Have you looked at this document ?
Setting mode = 1 means "PCM interface is valid".
Setting to 0 means SD card.
Also, in these cases, you should generally try the query command first - to see its response: AT+SD2PCM=?
