How can make a system which have two circuit. And one is place at ground floor and another is in roof. We send voice (like call) one from other by pushing a switch and vice versa. It may be wired system. I want to make this system. Can you please help me?
closed as too broad by Transistor, brhans, Chris Stratton, Scott Seidman, Dave Tweed Nov 26 '18 at 17:54
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ This is a vague question as there are multiple ways to approach this. Did you have a particular concept in mind? I could technically say to talk into a tin can that is tied to a string and have the receiver listen to your voice through another tin can but I'm sure you want something more technical than that. \$\endgroup\$ – KingDuken Nov 26 '18 at 16:30
  • \$\begingroup\$ This system can be wired system. Do i need to make modulator and demodulator and then through a two wire line and received at other end. How can design a practical circuit. Which will work for this 15-20ft distance. The nodes are always output but when switch is push then it take input and send to the other node. Hope it will be clear. I am waiting for your answer. \$\endgroup\$ – Shanu Dey Nov 26 '18 at 16:36
  • \$\begingroup\$ You should edit your question to show what intercom circuits you found in your research. Then ask for help if there is something you don't understand about the circuit. \$\endgroup\$ – Transistor Nov 26 '18 at 17:11
  • \$\begingroup\$ Ok let me take some time and research more and then i will inform you. Thank you. \$\endgroup\$ – Shanu Dey Nov 26 '18 at 17:19
Sounds like you need something like this simple intercom. There are plenty of similar circuits about if you look. If this looks too complex, then buy something off eBay!
  • \$\begingroup\$ It is nearly something what I want. Thank you. Let me study this circuit. \$\endgroup\$ – Shanu Dey Nov 26 '18 at 17:51
