I am trying to build this circuit enter image description here but I don't know how to test it. When I am measuring the voltage on the gate of high side mos is almost 12 volt like VCC. So to speak .. the boostrap circuit isn't working. Dou you have any ideas ?
    \$\begingroup\$ The bootstrap circuit will only work if the device is actively switching. \$\endgroup\$ – Edgar Brown Nov 28 '18 at 22:33
Consider this typical circuit from this website:
When Lin is high and thus Q2 is 'on', the output is low and C2/C6 are near ground on the negative side. Vcc then charges the capacitor through diode D1. This provides a voltage source relative to the source of Q1.
When Hin goes high those charged capacitors are used to drive the gate of Q1 high. The charge on the capacitors will eventually be depleted,and Q1 will no longer be able to turn on fully. Some drivers contain a second UVLO for the high side switch, preventing damage which could occur from having the high side transistor partially turned on. The IR2101 does not appear to have that. See, for example, this application note.
So to use this, you should be switching both Lin and Hin actively at a reasonable frequency (typically in the kHz).
  • \$\begingroup\$ UVLO has absolutely nothing to do with the bootstrap voltage, it detects the VCC voltage to prevent driving under conditions where the low side is not driven completely. This is because the failure to provide a low on the external FETs will result in no charge on the bootstrap caps. The circuit would still try to work, but the high side switch FET would potentially burn out due to high dissipation. \$\endgroup\$ – Jack Creasey Nov 29 '18 at 17:26
  • \$\begingroup\$ @JackCreasey There is a second UVLO on the high side bootstrap supply that protects the high side MOSFET from inadequate drive voltage. \$\endgroup\$ – Spehro Pefhany Nov 29 '18 at 17:42
  • \$\begingroup\$ Where is the second UVLO? I don't see it in the datasheet. There is a single UVLO that detects when VCC is too low and prevent both channels, but the UVLO has nothing to do with the high voltage being used ...only the VCC serving the chip. \$\endgroup\$ – Jack Creasey Nov 29 '18 at 20:40
  • \$\begingroup\$ @JackCreasey Ah, you might be right for that particular case. I don't see it either. This generic app note shows it, and all the IRF drivers I've used have it incorporated. I'll edit the answer. Thanks. \$\endgroup\$ – Spehro Pefhany Nov 29 '18 at 20:53
If you read the datasheet for the IR2101 then you can see that the bootstrap capacitor only increases Vb when there is a transition on the output of the external high side FET. So the high side boostrap uses positive feedback to increase the Gate drive voltage and can only work if there is a path to ground to allows the bootstrap capacitor to charge when the external high side driver is off.
So to test the unit you need to drive HIN and VB will ONLY increase if you have a load to allow the cap to charge when the high side switch is off. In other words you need some load to hold Vs lo.
Notice from the internal schematic that LIN has nothing to do with the bootstrap.
  • \$\begingroup\$ My HO is always high no matter if I apply pwm or not... \$\endgroup\$ – pantarhei Nov 29 '18 at 9:14
  • \$\begingroup\$ @pantarhei I assume you mean HIN …..it has to be toggling to get the bootstrap to work …..in a permanent hi or lo state it does not bootstrap. \$\endgroup\$ – Jack Creasey Nov 29 '18 at 17:09
  • \$\begingroup\$ I have two ICs IR2101. With the same configuration on the breadboard. When I apply pwm on HIN one IC has HO pin always 12 volts no matter what and the other one has on HO pin the pwm. Which one is working correctly ? I should mention that if I switch the ICs between them the first one that had HO pin always 12 volts now has a PWM and the other has on HO pin always 12 V. \$\endgroup\$ – pantarhei Dec 1 '18 at 12:26
  • \$\begingroup\$ @pantarhei Check your breadboard build ...there must be a difference. \$\endgroup\$ – Jack Creasey Dec 1 '18 at 16:36
  • \$\begingroup\$ Anyway, but can you tell me which one is the normal behavoir. Always 12 V on HO pin or PWM ? \$\endgroup\$ – pantarhei Dec 1 '18 at 17:55
