-1
I am measuring a power mosfet with a multimeter. The voltage at the source with respect to GND is ~291V. The voltage at the drain with respect to GND is ~16V. The P-type mosfet is rated for 250V, so I'd expect it to be completely avalanching from S to D, but that is not occuring. When I measure the voltage with black probe on drain, and red probe on source, I get only ~2V. The mosfet is either broken, or I'm reading the mosfet wrong with the probes. Sound familiar to anyone?
    \$\begingroup\$ Sounds like you have strong E fields, and high source impedances. \$\endgroup\$ – analogsystemsrf Dec 1 '18 at 3:08
  • \$\begingroup\$ What is Mosfet Part number ? Rated for 250 volts doesn't mean that the device will fail at exactly 250. \$\endgroup\$ – Marla Dec 1 '18 at 3:09
  • \$\begingroup\$ mouser.com/datasheet/2/427/sihfr921-108641.pdf \$\endgroup\$ – snowg Dec 1 '18 at 3:10
  • \$\begingroup\$ @analogsystemsrf Chip broke or naw? Is it impossible to measure Vsd with a multimeter from the terminals of the chip itself? Is measuring from ground individually the 'correct' way? \$\endgroup\$ – snowg Dec 1 '18 at 3:12
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
