Please excuse my confusion, because I really don't understand what the "150mA max continuous cathode current" means on the datasheet for the LM431. I'm also not sure it'll work in the crowbar circuit I intend to build. (I suspect it will, seeing as it's rated for 36V).
I have the following circuit diagram, based on a Wikipedia description of a crowbar circuit:
D3 leads to a(n) LM3481 used as a SEPIC (Pg 26) to output 7V for a load that draws between 500mA to 1A (1.25A to be on the safe side).
This leaves me with a number of questions, assuming I want the crowbar to reject (short out) input voltage higher than 35V:
  1. If the input voltage at D1 is higher than 35V (unlikely, but possibly as high as 40V), will the LM431 become damaged or will the fuse burn out first?
  2. Will a polyfuse/PTC work for F1? What part type/specifications should I look for?
  3. To what should I connect the wiper for R1, GND? Does R1 need to be a POT or can I use a fixed resistor?
  4. What are the values for R1, R2 and R3?
  5. DI1 is a TRIAC. What specifications should I look for?
  6. Does the 150mA mentioned in the data sheet have anything to do with the load after D3? What is it actually telling me?
  7. I know that I can use Vout ~= (1 + R1/R2)Vref to work out what R1 and R2 should be, but I don't know how I work out Vref. Is that Vin from D1 or from the LM431?
I have seen this as a proposed solution, but apparently the MOSFET doesn't short to ground (according to one of the comments).
  • \$\begingroup\$ Asking "what part(s) should I use?" is a good way to get your question closed as off-topic. Try asking something more like "what specs should I look for?" instead. \$\endgroup\$ – Hearth Dec 1 '18 at 15:53
  • \$\begingroup\$ Is your goal to blow the fuse in the case of overvoltage? Do you want it to auto-reset after some specified time? Or is it good enough to have to replace a fuse each time? \$\endgroup\$ – jonk Dec 1 '18 at 19:54
  • \$\begingroup\$ @jonk Yes, the goal is to blow the fuse in the case of overvoltage (> 35V). Auto-resetting after a few seconds would be good, but I don't mind if the fuse has to be replaced once blown. \$\endgroup\$ – Agi Hammerthief Dec 3 '18 at 6:50
  • \$\begingroup\$ @AgiHammerthief Added something that may be acceptable. \$\endgroup\$ – jonk Dec 3 '18 at 7:54
Something like this, then?
\$Q_2\$ is a big BJT easily capable of causing the fuse to burn out in the case of an over-voltage situation. (You could try something smaller, of course. But this BJT is way more than you need to make sure.)
Here, \$R_1\$ and \$R_2\$ are used to set the threshold voltage to trigger on. I've set the threshold just a little high, just by way of an example. But you can adjust these, as needed, to hit the point you want.
\$R_3\$ is designed to provide about \$7-8\:\text{mA}\$ for the base of \$Q_1\$. Assuming \$Q_1\$ is driven into saturation, this should still mean at least \$75\:\text{mA}\$ into the base of \$Q_2\$ (and probably a lot more than that.) I might consider adding a base resistor for \$Q_2\$, but since the point is to blow the fuse I'm not sure it's really needed. If you do add it, then something like this would be fine:
That should blow the fuse.
The main thing here is to adjust the values of \$R_1\$ and \$R_2\$ to get the trigger voltage you want. Or, use a \$10\:\text{k}\Omega\$ potentiometer in there, as appropriate, to allow an adjustable setpoint.
The voltage across the LM431 shouldn't exceed your trip-point setting, less a diode drop or so. You could add more circuitry to make absolutely certain to protect the LM431. But this arrangement may be okay for your needs.
  • \$\begingroup\$ Thank you; much appreciated. Any suggestions on what the specifications for F1 should be? \$\endgroup\$ – Agi Hammerthief Dec 3 '18 at 9:42
  • \$\begingroup\$ @AgiHammerthief I think you'd suggested \$1.25\:\text{A}\$. That sounds fine to me. You could select anything from \$1\:\text{A}\$ to \$2\:\text{A}\$ (or more.) \$Q_2\$ in the circuit can sink a LOT of current on its own. And it will, if permitted. \$\endgroup\$ – jonk Dec 3 '18 at 17:53
