I'm new to StackExchange.
I would like to know if it is possible to use a P2 connector to capture audio.
I already use it to play audio on headphones but I plan to pick up the audio from a smartphone and play it on a speaker I have.
Is it possible? If so, can you please tell me what could I do to achieve this?
Thanks in advance!
    \$\begingroup\$ Voting to close: Questions on the use of electronic devices are off-topic here. \$\endgroup\$ – Hearth Dec 2 '18 at 2:57
I never heard about a "P2" connector and neither does Google. If it is the 1/8" stereo plug used for headphones then it can pickup a stereo signal and feed a stereo amplifier. Two resistors can convert the stereo into mono to feed a single amplifier.
A headphones signal is too weak to feed a speaker without an amplifier.
