I'm planning to do a waveform generator using an FPGA board (spartan 6 board from diychips), however I am new to verilog so I am encountering a bit of a problem. I created a sine-wave sequence using MATLAB and imported it into my verilog code. Here's the code that should output the 7 bit sequence :
module dac7bit(input M_CLOCK, output reg [6:0] DAC);
reg[8:0] counter;
reg clk = 0;
reg[4:0] i = 0;
always @(posedge M_CLOCK) begin
counter <= counter+1;
if(counter==320)begin
clk <= ~clk;
counter <= 0;
end
end
always @(posedge clk) begin
case(i)
5'b00000 :DAC <= 7'b1000000;
5'b00001 :DAC <= 7'b1001111 ;
5'b00010 :DAC <= 7'b1011110 ;
5'b00011 :DAC <= 7'b1101011 ;
5'b00100 :DAC <= 7'b1110110 ;
5'b00101 :DAC <= 7'b1111100 ;
5'b00110 :DAC <= 7'b1111111 ;
5'b00111 :DAC <= 7'b1111110 ;
5'b01000 :DAC <= 7'b1111001 ;
5'b01001 :DAC <= 7'b1110001 ;
5'b01010 :DAC <= 7'b1100101 ;
5'b01011 :DAC <= 7'b1010111 ;
5'b01100 :DAC <= 7'b1001000 ;
5'b01101 :DAC <= 7'b0110111 ;
5'b01110 :DAC <= 7'b0101000 ;
5'b01111 :DAC <= 7'b0011010 ;
5'b10000 :DAC <= 7'b0001110 ;
5'b10001 :DAC <= 7'b0000110 ;
5'b10010 :DAC <= 7'b0000001 ;
5'b10011 :DAC <= 7'b0000000 ;
5'b10100 :DAC <= 7'b0000011 ;
5'b10101 :DAC <= 7'b0001001 ;
5'b10110 :DAC <= 7'b0010100 ;
5'b10111 :DAC <= 7'b0100001 ;
5'b11000 :DAC <= 7'b0110000;
default: DAC <= 7'b0100000;
endcase
i<=i+1;
if(i==24) begin
i<=0;
end
end
endmodule
I have created a register DAC that I have mapped in the .ucf file, using this datasheet. The pins are then connected to the R2R DAC outside the board via jumpers. I am not sure if this is the way to do it (to map the pins), I got this idea from how this was done for the I/O board shipped with the FPGA board itself. Here's the .ucf file:
# DAC
NET "DAC<6>" LOC = P104;
NET "DAC<5>" LOC = P101;
NET "DAC<4>" LOC = P99;
NET "DAC<3>" LOC = P97;
NET "DAC<2>" LOC = P94;
NET "DAC<1>" LOC = P92;
NET "DAC<0>" LOC = P87;
# Clock signal
NET "M_CLOCK" LOC = P123;
However I could't probe anything, all of the pins were high. I thought that the problem might be with generating my own clock signal, or with the case() syntax, so I tried to just assign some 7 bit value to DAC register on each M_CLOCK cycle. Still, nothing has changed. Therefore I think that the problem is with either initializing the DAC register, mapping it, or assigning values to it, however I can't find anything that could help.
EDIT:
The problem was much more trivial than I expected. It was due to the software I was using. I had installed Xilinx ISE on a Windows 8 machine and some of the features (such as producing working bit .mcs files it would seem) were bugged. Once I got to my school computer that runs a working version of ISE the code worked as expected.
clk
? \$\endgroup\$
