I wish to drive a set of NEOPIXELS (ws2812b) using the STM32F4 discovery board, so far i managed to get a 800 kHz PWM signal using the CubeMX. enter image description here
And
enter image description here And the following code:
/* USER CODE BEGIN 2 */
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1);
/* USER CODE END 2 */
But when i add these lines of code
/* USER CODE BEGIN Init */
uint16_t pData[25] = {8,8,8,8,8,8,8,8,4,4,4,4,4,4,4,4,2,2,2,2,2,2,2,2,0};
/* USER CODE END Init */
//HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1);
HAL_TIM_PWM_Start_DMA(&htim1, TIM_CHANNEL_1, (uint32_t *)pData, 25);
My PWM signal just disappears, what do i need to do to control the PWM with DMA?
edit:
It is posting the DMA sequence, but the DMA needs to be changed to circular to see it on a scope
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$ – Nick Alexeev Dec 4 '18 at 0:45
The code was correctly transmitting the DMA sequence, but the DMA needed to be changed to circular or repeating mode to see it on a scope. When it was just running in linear or one-shot mode, I didn't have a chance to see the output the single time it was produced.
    \$\begingroup\$ Is this the solution to your issue, or just an additional clarification? \$\endgroup\$ – W5VO Dec 3 '18 at 17:03
