I am building a system which will measure and record the voltage of batteries. There are 8 channels in the system with each channel being capable of measuring 0-35V. The accuracy we have decided upon is +/- 0.02V. The LMV324 Opamp was chosen as it has a Input offset voltage of max 6mV specified. A 12bit ADC is being used with a 1.8V reference voltage.
I have built the circuit, and found that even with no input voltage applied, the output of the Opamp is 0.04V. I have two of these Opamps on the same PCB, and all output voltages between 0.038 and 0.04V with no input. At first I thought that noise/ripple from my DC-DC converter, which powers the Opamps may have been the problem. But then I switched over to a linear regulator and the exact same thing happens.
Could someone please explain why this may be happening?
Opamp data sheet: https://www.st.com/resource/en/datasheet/lmv324.pdf
  • \$\begingroup\$ The problem is "Low level output voltage" V_ol , the lowest output voltage on op-amp output when VDD=0V \$\endgroup\$ – M KS Dec 4 '18 at 8:49
    \$\begingroup\$ Why would you specifically choose an op-amp with such poor input offset voltage? \$\endgroup\$ – Andy aka Dec 4 '18 at 9:23
  • \$\begingroup\$ Sorry, I don't have much experience with Opamps. I didn't know that this was poor. What type of input offset voltage would be classified as 'good'? Specifically I have just calculated I need the Opamp output to be within 1mV of the input \$\endgroup\$ – Russell Dec 4 '18 at 9:25
Input offset means the op amp can see a difference of >6mV between it's inputs. The output can still be over 6mV. You need a rail to rail opamp which goes down to zero volts at its output. I don't know if there's anything cheap which can do that.
Here's a tutorial on input offset voltage https://www.analog.com/media/en/training-seminars/tutorials/MT-037.pdf
The usual way to get a zero output is to use a balanced dual supply. And, then some kind of protection circuit to make sure output is within uC input limits. This makes every single op amp ever made go down to zero volts.
Or, one can add the input with a bias voltage (65mV in this case) and then feed it to the op amp. But, this will likely introduce even more error.
If you can find an opamp that does have 0 V output, but has a high input offset, you can still use the LMV324. Set a gain on the LMV324 and feed it into the other opamp.
[The OP07 is not a rail to rail opamp. From the datasheet, with ±15V supply, output swing is ±12.5V max. That means, if power supply is single rail 5V, output will vary from +1.5V to +3.5V max, instead of 65mV to 4.99V for the LMV324 (typical), or even 5mV to 3.5V for the LM358 (typical)]
added At 3.3V single rail supply for the opamp, for measuring battery voltage, the LM358 is fine. I would try to increase the supply voltage a bit if possible to account for inter chip variations, as 3.3V leaves exactly 3.3-1.8=1.5V headroom (which is the limit for this opamp).
As Doodle and others say below, in reality a battery will never drop to zero volts, so rail to rail opamp is not really required.
Input null would be great for accuracy. However, if the OP is using a uC, the calibration can possibly also be done in software, if the input offset for the particular chip is stable (this is an assumption).
  • \$\begingroup\$ OP hasn't made it clear the supply constraints for the Op Amp. You're operating under the Op Amp using a single supply where as I am suggesting based on a dual supply. \$\endgroup\$ – Doodle Dec 5 '18 at 9:35
  • \$\begingroup\$ @Doodle Well... you are not entirely right. (With dual supply) Low input offset will only ensure output is zero, when input is also zero. That is an ideal op amp, and the OP07 comes close to it. However, on a dual supply, ANY opamp will reach zero volts, even if the input is not exactly zero. Unless one is building a multimeter, the OP07 is overkill. For the OP, 6mV input offset appears to be fine. Therefore the ordinary LM358 with 7mV input offset, and 5mV output with single rail, should also be perfectly fine. \$\endgroup\$ – Indraneel Dec 5 '18 at 9:44
  • \$\begingroup\$ @Doodle one can also operate the LM358 with dual supply to get exactly 0 V output (but off course that would be kind of stupid). For a thermocouple or multimeter, I would definitely use a OP07 or better with dual supply. But for measuring a battery ...? \$\endgroup\$ – Indraneel Dec 5 '18 at 9:48
  • \$\begingroup\$ The point of suggesting the OP07 was the null pins that allow for you to make the output zero when the input is zero pretty easily. I'm just working off the OP's stated requirements rather than the application. \$\endgroup\$ – Doodle Dec 5 '18 at 9:52
  • \$\begingroup\$ @Doodle OP has now stated the opamp supply to be 3.3V single rail. You are not wrong, just a bit off the mark. I don't hold a grudge. Yes, you are right about the irrelevant part too. We are just banging our heads here. \$\endgroup\$ – Indraneel Dec 5 '18 at 9:54
