appreciate if anyone is able to help to identify this connector in the photo below.
Basically i am trying to identify different types of connectors/ports around different PCB to find debug ports.
thank you in advance! :)
edit: dimensions length: 5mm width: 12mm
additional info: this connector seem to be used in automotive tcu
  • \$\begingroup\$ It would help if you provided the dimensions of the connector. \$\endgroup\$
    – Ron Beyer
    Dec 5, 2018 at 2:39
  • \$\begingroup\$ oops sorry, added dimensions @RonBeyer \$\endgroup\$
    – Ben
    Dec 5, 2018 at 3:58
This appears to be a Hirose DF20F-20DP-1V(56) this image shows with the pick and place cap in place, however appears to be the one.
Here is a link to the drawing. https://www.hirose.com/product/download/?distributor=digikey&type=2d&lang=en&num=DF20F-20DP-1V(56)
