I have a design with several rooms in it. I did a part of the routing and I don't know what I did, but now when I move a room, the components don't move with it.
I found something in the documentation:
Once component(s) have been assigned to a room, they move when the room is moved. To move a room without moving the components, temporarily disable the associated Room Definition rule - either in the PCB Rules and Constraints Editor dialog or in the PCB Inspector panel (with the room in question selected in the workspace).
But I wasn't successful with this help...
What should I do?
Rules->Placement->Room Definition->Make sure rooms are enabled.
Ok, after a clik on the menu "Design / Import changes", components move again with the room.
I don't know why.
    \$\begingroup\$ You should add a little more detail into this answer if you want it to be helpful \$\endgroup\$
    – MCG
    Dec 5, 2018 at 14:44
    \$\begingroup\$ I did my best.. \$\endgroup\$
    – Julien
    Dec 5, 2018 at 15:28
