I have a fairly simple VHDL design that looks like the following:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity myCode is
    port (
        input_clock : in std_logic;
        do_increment : in std_logic;
        counter_out : out std_logic_vector(4 downto 0)
end myCode;
architecture Behavioral of myCode is
signal internal_counter : unsigned (4 downto 0 ) := (others => '0');
signal do_increment_delay : std_logic := '0';
begin
counter_out <= std_logic_vector(internal_counter);
process(input_clock)
begin
    if(rising_edge(input_clock)) then
        do_increment_delay <= do_increment;
        if( (do_increment = '1') and (do_increment_delay = '0') ) then
            internal_counter <= 1 + internal_counter;
        end if;
    end if;
end process;
end Behavioral;
The goal is to increment the counter_out by 1 on the rising edge of "do_increment" signal only.
When I look at my running design in ChipScope (running on Spartan-6 FPGA), I see that the code is doing what is expected:
working example
However, during periods of time when both do_increment and do_increment_delay are low, the counter begins to increase on its own:
what's going on here?!
There is no other assignment statement to counter_out anywhere.. the chipscope clock is the same one used as the input_clock to myCode. I have scoped out the do_increment physical signal into the FPGA and it is not noisy.
Any ideas?
    \$\begingroup\$ You should create a testbench so you can simulate this code and probe internal signals. Make sure that you are not changing data inputs and the clock at the same time. \$\endgroup\$ – Elliot Alderson Dec 6 '18 at 2:23
Is do_increment an external signal? If it's asynchronous to input_clock, then you should synchronize do_increment to your clock before using it in your logic.
I suspect noise on the do_increment line. The scope probe might be enough to suppress the noise. Does the counter increment when you are looking at the do_increment signal with the scope? You can't trust the chipscope version of do_increment because it does not come from a synchronous element clocked by the chipscope clock. As others have said, you need at least one register on the do_increment before using it in your logic. I am sure there is a warning telling you this.
