I am making a PCB design of buck converter 30-50V to 12V using the Max5033 IC. https://datasheets.maximintegrated.com/en/ds/MAX5033.pdf
This is the first time, I am doing a PCB design for a converter so I would like some guidance.(online I already read a few pcb design guidelines)
  1. I am not sure of the location of C27 (the output capacitor). At first, I had it on the lower side(same layer) of the IC to have it closer to the Inductor and especially the input capacitor for the return current path during on-time. But then I visualized that the IC would be in the center of the loop for both the on and off time, thus I replaced it to the top side. Is my reasoning correct?
  2. In the datasheet they recommend to have star point ground connection. I have tried to make such a connection by connecting the ground of the IC (pin 3 and 6) to the input capacitor ground. But I am not sure if this the way to do and if this is the best location to make the connection. For example If I would connect it to the anode of the diode the trace would me shorter. Is this correct?
  3. Any more recommendations on the layout is highly appreciated.
NOTE: please do not comment on the component values as those might not be correct in the attached schematic
EDIT : Based on the answers and comments below I have made some changes
I have reduced the trace of the switching node and I increased the width of the traces which carry the load current , in particular the GND node.
  1. Can you comment on whether the grounding is correct? (star point)
  2. And I am bit unsure whether I should decrease the size of the trace of the LX pin. I have read that the switching node can act like a antenna, so the area should be kept small at the same time the application node says to use LX (among other pins) for thermal management.
  • \$\begingroup\$ Have you looked at PCB Layout Considerations in the datasheet? \$\endgroup\$ Commented Dec 6, 2018 at 11:28
  • \$\begingroup\$ of course I did \$\endgroup\$
    – Navaro
    Commented Dec 6, 2018 at 11:33
    \$\begingroup\$ Welcome to EE.SE! Looks terrible! The distance (or area drawn by) U3-L3-D3-C27 should be minimized at pretty much all costs. Where is your ground plane? \$\endgroup\$
    – winny
    Commented Dec 6, 2018 at 11:45
  • \$\begingroup\$ I understood the part of the switching node, but I was planning to use the internal layer as ground plane @winny . \$\endgroup\$
    – Navaro
    Commented Dec 6, 2018 at 11:50
  • \$\begingroup\$ How many total layers for the PCB? What's the ESL and ESR of C26 and C27? \$\endgroup\$
    – winny
    Commented Dec 6, 2018 at 12:10
I see a few issues on this design. In step-down converters you have 3 pins that carry all of the current, and those are VIN, GND and LX. These are the pins to which you must give the priority in terms of track width and length.
Looking at the design you show, you have not followed any of these rules. I suggest you make sure that all components on LX are as close as possible to the pin, taking priority on the diode and inductor. the output capacitor doesn't need to be that close, but the input capacitor should.
Try to make the GND track nice and wide, giving priority to the GND path between the MAX5033 to the diode and the input capacitor.
In theory a 0.5mm track should be enough in all cases, but for the tracks mentioned above, the wider is better, as it will lower the impedance, and reduce any noise that might bite you later.
It is worth looking at the app notes on Maxim's website such as https://www.maximintegrated.com/en/app-notes/index.mvp/id/4381 The layout they have done here is not optimal, but the designer here had space constrains, so had to compromise, but it is a good start.
  • \$\begingroup\$ your feedback is appreciated: but to you the diode is not close enough to the LX pin? and the current through the inductor is “continous” so can you explain why it should be close to the Lx pin? \$\endgroup\$
    – Navaro
    Commented Dec 6, 2018 at 11:18
  • \$\begingroup\$ The diode is close enough. \$\endgroup\$
    – Elmesito
    Commented Dec 6, 2018 at 11:32
  • \$\begingroup\$ then I dont understand your answer. \$\endgroup\$
    – Navaro
    Commented Dec 6, 2018 at 11:34
    \$\begingroup\$ If you look at the datasheet, the LX pin is connected internally to the drain of a Mosfet. The diode has the job of clamping the voltage spikes that come from the inductor. That is why the path between these three elements must be short. \$\endgroup\$
    – Elmesito
    Commented Dec 6, 2018 at 11:39
  • \$\begingroup\$ I suggest that you look at how a buck converter works. see here, for a good explanation. radio-electronics.com/info/power-management/… \$\endgroup\$
    – Elmesito
    Commented Dec 6, 2018 at 11:42
I'll add also my two cents. This is how I usually route my bucks. I like to use area fills usually... Never had problems so far.
As user156046 told most important thing is to keep LX components close and return paths clear and short.
Have a nice day
Edit: Don't care about physical size of tantalums and inductor.. I just picked something fast.
enter image description hereenter image description here
  • \$\begingroup\$ thanks for sharing...the only thing that confuses me is whether the ground plane you used with copper fills is a better way to reduce noise compared to a star ground point wich is mentioned in the IC. By doing it with copper fills, the power return currents can “disturb” the IC right? I understand that for this power rating this might not be an issue but I just want to learn how to properly design. \$\endgroup\$
    – Navaro
    Commented Dec 6, 2018 at 16:03
    \$\begingroup\$ @Navaro the only thing that confuses me is whether the ground plane you used with copper fills is a better way to reduce noise compared to a star ground point wich is mentioned in the IC. Actually, if your PCB has a big ground plane (bottom layer or inner layer) and all the ground connections is done only to this plane then this means that you automatically did star grounding. Think of the ground plane as a huge "star point". Providing a low-impedance return path (or ground) is always good. \$\endgroup\$ Commented Dec 7, 2018 at 5:04
    \$\begingroup\$ Well said Rohat. Just like that! \$\endgroup\$
    – JuhoR
    Commented Dec 7, 2018 at 10:40
