Today I looked upon my desk: as you can see in the screenshot below, there are three plastic boxes containing A/C adapters for (I think all in the 12-20V and 1-2A range):
  • screen device
  • notebook
  • notebook docking station
Altogether they are worse almost 2 kilograms metal and plastic.
My question is: are these dimensions already optimal, or could be same functionality put in significantly smaller size (like more than a half, or even 1/10?)
Or is this is by physics already mature technology which is not expected to improve?
Note: with keyword "feasible" I mean the fact that I understand that miniaturization would cost more: "not feasible" means in this context like a 10-100x fold price increase.
    \$\begingroup\$ Things tend to get smaller with time. \$\endgroup\$ – Andy aka Dec 6 '18 at 12:47
  • \$\begingroup\$ accountants tend to stop engineers producing the "best possible, most reliable" option for the "cheapest thing" that works.... Always driven by the bottom line ie PROFIT... \$\endgroup\$ – Solar Mike Dec 6 '18 at 13:16
    \$\begingroup\$ The plastic cases consume most of the volume. Inside the plastic, you'll find a transformer which needs a certain CORE VOLUME to store the energy for ONE cycle of the chopping frequency. 10X faster chopping allows 10:1 volume shrink, or about 2:1 shrink in each dimension. You also need high-voltage capacitors to store energy for 1/120th of a second. Tolerating MORE ripple at 120Hz will allow a smaller high-voltage capacitor. And you need to remove heat, right? That needs pieces of metal to take heat from the MOSFET and the transformer, and pass that heat out thru the plastic. And EMI filters. \$\endgroup\$ – analogsystemsrf Dec 7 '18 at 4:42
  • \$\begingroup\$ @analogsystemsrf all previous answers have been like, give the engineer more money and there will be a masterpiece; from your answers I read there is not so much to shrink actually. \$\endgroup\$ – J. Doe Dec 7 '18 at 4:57
So, first of all, cost is a very important factor limiting the shrinking of power supplies.
For example, an Apple iPhone and macbook chargers have relatively high power density (power going through the power supply per volume, in this case), but that came with a high engineering price, and expensive components and manufacturing processes.
Of course, there's theoretical limits. There's only so much power you can push through the magnetic core of a flyback transformer per time. More importantly, isolation distances still have to be kept to avoid danger.
Mainly, this is a question of using better controllers, higher-quality switching transistors and transformers to minimize size, along with investing more to make components withstand the larger temperatures inherent to reduced cooling surface.
As at least better controllers and switches are semiconductors, they still tend to get cheaper over time, and hence, more devices can economically feasibly have more efficient power supplies. Efficiency implies less needed cooling surface, so that might allow for smaller supplies over time.
The size (and weight) of these power adapters is always a compromise between price / size / weight. Yes they can be made smaller, especially with recent developments of GaN (Gallium Nitride) transistors, read more here.
These transistors are "better" switches than most of what is used today. Being "better" means less power is lost in the adapter and that means less cooling (area) is needed and size and weight can decrease.
As with nearly all new technology there is still a price to be paid, these GaN transistors are more expensive. Also the adapters need to be re-designed to take advantage of these new transistors. That takes time and money.
Not every customer and/or manufacturer cares about having a smaller power adapter. Would you be willing to pay for example $10 extra just to have a smaller power adapter?
  • \$\begingroup\$ in fact, depending on how much smaller it could be, I would! \$\endgroup\$ – J. Doe Dec 6 '18 at 12:53
  • \$\begingroup\$ The first thing that catches my eye in the power supply you have linked is the huge cup core coil. That's for sure a means of good efficiency, but it comes at the incredible price of making the device sensitive to mechanical shock. Drop it on the floor a few times and this core is gone. – Engineering fail. \$\endgroup\$ – Janka Dec 6 '18 at 13:03
    \$\begingroup\$ @J.Doe you might, but most devices sold in this world stand under extreme competitive pressure – for example, if two screens had the same specs, but one was 10€ more expensive, you wouldn't buy the more expensive one. It's hard to advertise "small power supply". \$\endgroup\$ – Marcus Müller Dec 6 '18 at 13:06
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
