I was given a practice problem as listed below. It says that the solution is in the form of a second order differential equation, but I thought that only RLC circuits were 2nd order. Am I missing something or is the textbook solution wrong? The values aren't necessarily important as it is the approach. To clarify the value beings solve for is the voltage at some time t ---> v(t).
My attempt:
node 1: 5cos(t) = v(t)/R + L(di/dt)
New contributor
Jeffery Epenstein is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
  • When does the switch close? Are you looking for a solution for the time after the switch closes? – Elliot Alderson Dec 6 at 15:54
  • yes, at t=0. I updated the diagram – Jeffery Epenstein Dec 6 at 16:01
  • If the switch closes at t=0 then the source no longer has any effect on the circuit. How did you end up with the 5cos(t) in your result? – Elliot Alderson Dec 6 at 23:54
Jeffery Epenstein is a new contributor. Be nice, and check out our Code of Conduct.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
