I was hoping someone could tell me what type of connector this is.
This is in an arcade cabinet connecting the speaker wires to a Sega amp (part number sj25-0361-01).
The width from outside edge to outside edge of the housing for both pins is .29 inches.
Thanks in advance!
photo of connector enter image description here
  • \$\begingroup\$ how big is it?? \$\endgroup\$ Commented Dec 7, 2018 at 3:39
  • \$\begingroup\$ appears to be a molex connector \$\endgroup\$ Commented Dec 7, 2018 at 4:25
  • \$\begingroup\$ Part numbers or specs of the parts this connects to may help as well and if you measure the dimensions as accurately as you can and provide a diagram. If you can't do that, put a common coin or banana in the picture for scale. Show a picture of the connector/header that this plugs into. Don't really use a banana. Use a commonly known coin. \$\endgroup\$
    – K H
    Commented Dec 8, 2018 at 1:19
  • \$\begingroup\$ The cabinet itself isn't really relevant since the insides have been replaced from another machine - however, I found the part number of the amp it connects to and added to the question. \$\endgroup\$
    – MikeM
    Commented Dec 8, 2018 at 3:04
  • \$\begingroup\$ Thank you @jsotola for adding the image of the amp. \$\endgroup\$
    – MikeM
    Commented Dec 8, 2018 at 18:40
This appears to be a Hirose connector from the EnerBee Series DF22
Take a look at part DF22C-2S-7.92C
Here is a link to the Datasheet. https://www.hirose.com/product/en/download_file/key_name/DF22/category/Catalog/doc_file_id/31682/?file_category_id=4&item_id=43&is_series=1
  • \$\begingroup\$ That really looks like it could be the one. Thank you, never would have come up with Hirose on my own! \$\endgroup\$
    – MikeM
    Commented Dec 11, 2018 at 20:16
That's an AMP Universal Power connector. Sega used them on the Naomi cabinets.
The two pin housing to plug into that board is part #176271, and the pins are #175151 (or 175152 for larger wire). These are female pins for the male plug. Digikey should have them.
See https://wiki.arcadeotaku.com/w/AMP_Universal_Power for more info.
