Is it possible to use a FET430, MSP-FETFlash or similar programmer to program and then blow the security fuse of the MSP430 devices?
We have 500 which already been soldered on the boards and were not programmed first.
  • \$\begingroup\$ Thanks. We recently solved the problem with a back door software fix but this is good information. \$\endgroup\$ Mar 14, 2019 at 20:48
Actually only 2 TI programmers can blow fuses (electrical and software fuses) on the MSP430 MCU line:
MSP-FET430UIF (the white box, mini USB)
and
MSP-FET (the black box, micro USB)
enter image description here As per document: SLAU647M from TI, page 4. But none of the eZ or MSP-EXP can.
And YES, you dont need full JTAG, it's possible to flash fuse with SBW (spy by wire), but you need to add a protection resistor (to protect TCK pin from the 6V out of the TEST/VPP pin)
SWD blow fuse with resistor protection
Full detail from TI forum here: https://e2e.ti.com/support/microcontrollers/msp430/f/166/t/353234?Not-Able-to-blow-security-fuse-in-MSP430G2553
Note: pay attention to the programmer's pinout in SWD mode: it's completely different from the JTAG pinout label on the back of the product.
With the MSP-FET (the black with micro-USB one), it's used at my factory to blow fuse for small production batches on MSP430G2553 devices.
Finally, for the physical fuse burning (such as MSP430G2553) a quick and dirty hacky solution: apply 6V directly on the TEST pin and it's supposed to burn the interface with 100mA in 1ms.
Yes the MSP-FET430UIF supports blowing security fuse to protect code.
From the website
Supports JTAG Security Fuse blow to protect code
Source - http://www.ti.com/tool/MSP-FET430UIF
FYI you need to have a JTAG header to use the function. and you are not using the 2 wire JTAG/ Spy-bi-Wire
