What would the magnitude Response curve for a Resistor, Inductor and Capacitor look like [with parasitic effects not ideal components] ? From what I have gathered they would look something along the lines of:
these are log-log graphs.
Resistor: enter image description here Inductor:
Capacitor:
Resistor: At high Frequency inductor characteristic dominates jwl hence impedance increase, capacitance would go to zero and R would become negligible.
Inductor: there is the peak there due to the resonance otherwise straight line gradient 1.
Capacitor: straight line gradient -1, not sure of any parasitic effects here?
Are these correct if now I would love to hear your contributions. If my explanations are lacking anything please add on for better understanding.
To add on to this, If I where to draw the circuit symbols of these non ideal passive components what would they look like?
Many thanks.
  • \$\begingroup\$ This would probably be better as three separate questions. \$\endgroup\$ – The Photon Dec 8 '18 at 1:06
  • \$\begingroup\$ What do you mean by magnitude response? On their own they are just two terminall components and, without other components, there is no input and output to differentiate. So, what do you mean? \$\endgroup\$ – Andy aka Dec 8 '18 at 9:50
  • \$\begingroup\$ Not using Logarithmic graphs a Reactive Inductance increases linearly with frequency so the Voltage peaks of an AC waveform decreases with increasing Frequency. Reactive Capacitance decreases Exponentially with increases in Frequency so an AC Voltage will increase in Peak to Peak voltage as the frequency increases if passed through a capacitor. A resistor has series reactive inductance and parallel reactive capacitance. It has 1/f noise so only the inductance has a useful frequency response as the capacitance is over-run by 1/f noise \$\endgroup\$ – Danny Sebahar Dec 8 '18 at 11:13
  • \$\begingroup\$ You write '\$ R \$' and '\$ |Z| \$' at your graphs. If this applies to the capacitor graph also then the concave decay in impedance isn't so strange as it's \$ |Z| = (\omega L)^{-1} \$. \$\endgroup\$ – joe electro Dec 26 '18 at 6:06
I think the graphs you have are not correct in general. You can't draw generalizations without discussing the frequency range of interest and physical construction of the components.
Essentially every real component can be modeled as a combination of ideal components. The more ideal components you keep adding the higher order and more precise your model becomes. Once you do the transfer function of this "real approximation" model using ideal components you will get a bode plot which will show you how the part will behavior under various frequencies.
It is true that often a resistor will first start looking like an inductor, a capacitor first like an inductor and an inductor first like a capacitor as you get outside of their expected performance range, but this is very much a rule of thumb to be taken with a grain of salt.
For example below are some first order approximations that are good enough for most EE work and rooted in physics...but precise applications may require more ideal components to model various behavior than is even shown here.
Here is a resistor:
Here is a capacitor:
Here is an inductor:
Here is a decent intro to bode plots.
Addendum
Here is a Vishay study on frequency response of thin-film resistors
    \$\begingroup\$ Thank you for your response. Considering a series network for wire wound resistors, if the frequency was to increase to very high levels, would the overall impedance of the circuit increase? and would also the phase of the circuit begin to change from 0-90 as it starts to act like an inductor. \$\endgroup\$ – fred Dec 8 '18 at 15:48
  • \$\begingroup\$ @fred I don't have the data and what is "very high frequency" will depend on the particular component. There are multiple wiring methods too (eg simple vs bifilar) which would impact my answer. In general for a simple wirewound resistor I would expect it to first behave as a resistor, then as an air core inductor and at even higher frequencies the inter-winding capacitance would probably start to dominate. Signal phase will follow the rules for what the apparent impedance of the circuit is at that frequency. PS Also added study on thin film resistors FYI as an example. \$\endgroup\$ – Gonzik007 Dec 8 '18 at 21:04
Here's some general points;
  • tracks and axial parts are 1nH/mm +/-50% typ depending on geometry
  • shunt capacitance depends on surface area/gap ratio
  • crosstalk can be computed as coplanar stripline in nH/cm and pF/cm for some geometry
    • transfer function depending on input/path impedance ratio.
  • Common Mode coupling depends on stray EMF and MMF , imbalanced impedances, proximity
  • CM noise is common and is reduced with balanced low impedances, CM choke (= "Baluns") to raise and balance the CM Z
    • then add shunt ground caps as Pi filters to attenuate with 2nd order CM noise reduction.
