10x bidirectional diodes 1.5KE400CA in series, balanced, then the chain in parallel for DC line protection. Breakdown voltage 400V per diode. Still got 10kV+ voltage spikes (picture below, x100000 attenuation). Why?
Edit:
Pulse shape and duration varies greatly (another example pictured below).
Rise time for the first oscillation: 10-20 ns.
Estimated inductance: ~20 uH.
The negative peak is timed at 8 us, way over the clamping voltage (7kV peak and 4kV clamping voltage) and TVS diodes still not conducting.
Edit 2:
Equivalent circuit pictured below. D3 undergoes catastrophic failure on higher voltages. (Scope readings shown here ~ 300V; real working conditions ~3kV)
Edit 3:
Equivalent circuit, measurements by precision shunt.
Edit 4: Hardware set-up. Power electronics module.
  • \$\begingroup\$ What does the input pulse look like? Rise time? Series impedance? And, very important, what is the estimated inductance of your series assembly? \$\endgroup\$ Dec 8, 2018 at 0:07
  • \$\begingroup\$ Looks like measurement error with ringing. Show your layout and probe methods and ground length \$\endgroup\$ Dec 8, 2018 at 0:40
  • \$\begingroup\$ Hi. It's a pulsed DC application, resembling a short circuit. Voltage drop on a precision shunt gives the same pulse shape. So it's just a shunt and x10 attenuation scope probe. \$\endgroup\$
    – Maris
    Dec 8, 2018 at 1:08
  • \$\begingroup\$ Show a detailed diagram of your test setup if you want proper help. \$\endgroup\$
    Dec 8, 2018 at 9:45
  • \$\begingroup\$ I have read this three times. I still have no idea what the energy source is for the spike or where or how you have connected your probes. But a 20mV pulse can sometimes couple into an oscilloscope via channel-to-channel crosstalk, or directly into the probe wires. I suggest adding a photograph of your test setup. And disconnect any unused probes from your oscilloscope. \$\endgroup\$
    – user57037
    Dec 9, 2018 at 0:59
The traces that you are capturing on the oscilloscope are not very compelling in terms of being true signals. When trying to measure small signals arising from high dV/dt or di/dt events, it is easy to deceive yourself, because small amounts of the pulse energy can couple into the oscilloscope through an unintentional path.
In particular, this circuit has a voltage divider formed by a 3 Giga-ohm resistor and a 30k resistor. If any energy can couple directly to the divider node, the scope will pick it up, and you will think it represents a real and true signal. Because of the divider factor, this mistake can cause you to dramatically over-estimate the actual voltage at the top of the divider. High voltage probes exist which would allow you to probe the input voltage safely and directly. You could also reduce the divider factor so that the input signal is more like several volts instead of 100mV. If the signal scales accordingly, it is more likely to be real.
A similar concern applies to your shunt measurement. Any voltage which couples to the oscilloscope input will cause you to estimate a large current (because the shunt is so small). One workaround for this would be to use a current probe to measure the current more directly. Current probes are available which can clamp around any conductor in the circuit. For example, see the picoscope product TA167 (2000 Amp current probe). If possible, a slightly larger shunt might help, too, because it will increase the signal amplitude.
Another idea, as long as your shunt is very low resistance, and as long as the anticpated voltage across the shunt is not higher than the oscilloscope maximum input voltage, you can use 50 Ohm coaxial cable instead of a scope probe. Then configure the oscilloscope input to 50 Ohms. This will somewhat reduce the voltage amplitude of any pulse energy coupling into the oscilloscope (but not the signal). If you get a dramatically different reading when you use 50 Ohm cable and 50 Ohm input impedance compared to 10x attenuating oscilloscope probe and high input impedance, then most likely you are getting some form of direct coupling.
Other ideas: Leave the probe attached to the oscilloscope, but do not attach the oscilloscope leads to the circuit under test. Run the experiment. Do you see a similar signal? Whatever signal you see on the oscilloscope under these conditions is NOT getting into the oscilloscope through a conductive path. That is something to think about.
I have had occasion to measure a lot of things so far in my career. I have not yet had to measure kV signals, but I have had to measure signals on current shunts in the presence of relatively rapid dV/dt signals, and it is challenging. The test setup really matters. The most accurate results can be obtained by using expensive active probes or dedicated differential probes with very short leads. Both of those are things you can consider purchasing or renting for your testing. The test setup is absolutely critical.
As far as TVS protection goes, it is generally best to put the protection as close as possible to the item being protected. If the TVS blows up, that just means you need a bigger TVS. You never want an inductor between a TVS and the protected item.
But the NUMBER ONE thing you need to figure out is WHY do you get a voltage overshoot (or do you really get a voltage overshoot?). Is it just cable inductance? So during the initial current spike, the cable inductance stores energy in the cable, and then the current cannot just stop, so voltage overshoots. That is common when a power supply is connected to a low ESR cap with a long wire. But in your case it is a bit perplexing because how do you get overshoot into a 20mOhm resistive load? The load is basically a short circuit already.
It might help if you are able to attach a picture of your setup or a full schematic of the real circuit that shows all parts and indicates wire lengths between the parts.
One other thought. If D3 is the part that is failing, it would be a good idea to probe at D3/C2 as directly as possible. As previously noted, your Giga-ohm resistor could be contributing to measurement error. If you can get a high-voltage probe across C2 and see what is happening, that would be very useful. Running the circuit at reduced voltages seems to be possible. So if you run it at 100V, what is the highest voltage you see at C2/D3? Maybe you can use a less exotic probe (I believe quite a few probes can handle well above 100V directly).
  • \$\begingroup\$ Old photo (Edit 4), main components are still the same. It is a High Energy Pulsed Power Supply - pulsed DC, discharge time (from microseconds to 2-3 ms max) is altered by L1 inductance. D2 and L1 have to withstand a maximum of 75 kA for that period. The load represents a relatively controlled short-circuit in different configurations. \$\endgroup\$
    – Maris
    Dec 11, 2018 at 1:25
  • \$\begingroup\$ Command and controll circuits are not an issue, as the transient energy is absorbed by the rectifier bridge (D3) charging C2. I've tried to protect the bridge with 12x serial diodes (300mA, 16kV each), to no avail either. The scope readings almost certainly are incorrect, but the transient is of at least tens of kV magnitude, quite energetic also ( first diode explodes ). Could this be the standard issue you mentioned about low ESR cap and long wires? Thank you very much for the comprehensive answer. \$\endgroup\$
    – Maris
  • \$\begingroup\$ This is a good example of "how not to design a high energy pulse generator" with excessive stray inductance and no controlled impedances and no specs in the question. \$\endgroup\$ Dec 11, 2018 at 1:43
  • \$\begingroup\$ Is D3 blowing up while the capacitor is charging? Prior to now, I had assumed that it was blowing up after the SCR fires, during the discharge event. If you are not sure because it all happens at once, it may be worthwhile to temporarily separate out the entire discharge circuit so that you can tell what is causing the failure. \$\endgroup\$
    – user57037
    Dec 11, 2018 at 3:58
    \$\begingroup\$ @mkeith It explodes after the SCR fires. I could separate the circuit for debugging. \$\endgroup\$
    – Maris
    Dec 11, 2018 at 10:02
