I am currently working on a project to create an amplifier which can use both physical and digital inputs to change the resistance of a potentiometer.
Is this possible without using sliders?
I know this sounds like a pretty odd question but I'm not sure how else I could do it as all the Pots I've found are either Digital or Analogue.
Thanks for your time.
  • \$\begingroup\$ You mean motorized pots? \$\endgroup\$ – Wesley Lee Dec 8 '18 at 19:59
Motorized potentiometers are a thing, although they are not used much on new equipment.
Another option is to use an encoder to detect knob rotation and use that to update a digital pot.
  • \$\begingroup\$ Hi Jasen, thank you for your help I'll look into these things tomorrow :D \$\endgroup\$ – Ben Robinson Dec 9 '18 at 0:32
Welcome Ben.
Maybe what you are looking for is a programmable gain amplifier (PGA) like this one (sorry the schematic looks quite old). Wikipedia page on programmable gain amplifiers gives also two links to integrated circuits. There is also a discussion on PGA here.
The gain depends on a binary word that could be generated:
  • either directly by your digital system
  • or from a physical slider and an analog to digital converter (ADC)
The choice between the two input is up to you.
  • \$\begingroup\$ Hi Charles, This sounds like a pretty neat Idea I'll have a look at this when i research Jasen's comment above. Thanks again Ben \$\endgroup\$ – Ben Robinson Dec 9 '18 at 0:32
