Below in the photo both SMPS power supplies powers some DAQ boards. I named them as 12V PSU1 and 5V PSU2. As you see the PSU1 and PSU2 are daisy chained at their mains entry(line, neutral, earth):
And here is the basic diagram:
Above both power supplies powers the different parts of the remote device Device 1. In real there are six of them but or simplicity I draw one device. The PSU1 directly powers the device, the PSU2 powers the 5V part of the device through a USB Hub.
I named the nodes as A, B, C, D and E.
Knowing that in SMPS A E and C D nodes are capacitively coupled, is there a loop for high frequency across A B C D and E?
If there is can I eliminate that by cutting the daisy chain earth between D and E?
Edit:
Block diagrams of the power supplies:
And here is the power line filter.
-1
It seems to me that there is at least one ground loop between the line filter housing - the yellow cable - the mounting plate with housing - back to the line filter.
I suggest you disconnect the yellow cable from the line filter.
  • \$\begingroup\$ Thanks for the input I didnt think about it. Here is the exact entry module line filter eu.mouser.com/datasheet/2/358/typ_5707-1275588.pdf Are their housing coonnected to their erath terminal in general? See also my edit I also provided the block diagram of the two SMPS. \$\endgroup\$
    – user1245
    Dec 8, 2018 at 21:48
  • \$\begingroup\$ disconnecting the saftey ground is very rarely the answer. and certainly not the answer to an immaginary problem. \$\endgroup\$ Dec 10, 2018 at 20:07
-1
Yeah there's loops but they don't matter. USB signaling is primarily differential: so long as the ground is good it should all work fine.
if you suspect problems with the ground add more connections to ground.
Cutting ground connections so that fault currents would flow through USB cables has the potential to end very badly.
  • \$\begingroup\$ " add more connections to ground" what does that mean? \$\endgroup\$
    – user1245
    Dec 9, 2018 at 0:57
  • \$\begingroup\$ if something is misbehaving, ground it better. \$\endgroup\$ Dec 9, 2018 at 1:15
  • \$\begingroup\$ @Jasen That is a terrible advice. Ground loops have to be avoided in first place, which is why more ground is not always better. Additionally, when there is a problem related to galvanic coupling, one should remove the common ground path of two interfering devices. \$\endgroup\$ Dec 10, 2018 at 5:14
  • \$\begingroup\$ Oooh scare ground loops! if that weere the case gound planes would never be used - they provide for an infinite number of ground loops. \$\endgroup\$ Dec 10, 2018 at 20:09
  • \$\begingroup\$ @Jasen A plane is not the same as a GND loop. There‘s no induction/EMF happening within a plane. E.g. I‘ve never seen an inductive coil of an RFID system being replaced by a plane. \$\endgroup\$ Dec 10, 2018 at 20:56
