I have a a balanced stereo audio source, being fed into a headphone amplifier. Both source and amplifier are connected via a pair of 3-pin XLR cables, one for each channel. The amplifier then outputs to some studio monitor headphones.
Due to some hearing loss, my right ear has about a 1.5dB loss over the left. As such, I need to cut the left speaker down by around 1.5dB. Neither the source or amplifier have balance/panning controls.
I want to build a resistor-divider circuit that would sit between the source and amplifier which does the job of attenuating the left channel.
  1. How do I calculate the resistor values needed to reduce the left channel by 1.5db?
  2. Are there any special considerations required given that I'm using a balanced (positive, negative, ground) configuration for each channel?
XLR
  • \$\begingroup\$ Given the reactive load of the speaker, you'll need a voltage divider before the PowerAmp. Otherwise the frequency response will become ugly peaky, dippy. \$\endgroup\$ Commented Dec 9, 2018 at 13:36
  • \$\begingroup\$ The above is correct due to loss of dampening factor using an L pad attenuator for any given headphone load that requires the drive impedance to be much lower (<2% of load during bass series anti-resonance (high current) But if that doesn't matter then are these 8 or ? Ohm headphones? electronics-tutorials.ws/attenuators/l-pad-attenuator.html \$\endgroup\$ Commented Dec 9, 2018 at 15:26
  • \$\begingroup\$ Headphone and speaker impedance is never flat \$\endgroup\$ Commented Dec 9, 2018 at 15:31
  • \$\begingroup\$ Agreed with the comments that the pad needs to be before the amp, but it sounds like that's what the OP's proposing ("a resistor-divider circuit that would sit between the source and amplifier"), so I see no problem here. \$\endgroup\$
    – Nate S.
    Commented Dec 11, 2018 at 0:17
As Tony mentioned, the configuration you're looking for is called an L-pad attenuator (or for its balanced cousins, the H-pad, U-pad, or O-pad). These are pretty easily built in-line in XLR barrels.
1.5dB is small enough that all the online calculators I could find were giving negative resistor values, so you'll probably have to do the calculations by hand. This page explains the calculations you'll need to select resistor values: http://www.uneeda-audio.com/pads/. It also has info about building the circuit inside an XLR housing.
