I want to increase the armature contact time with pin 87 of any relays when coil is energized.
For instance, if the initial armature contact time is 2 seconds with 87 pin, how to increase the contact timing by 3 or 4 seconds?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI want to increase the armature contact time with pin 87 of any relays when coil is energized.
Relays in automotive use the 87 designation to indicate the terminal of the Normally Open (NO) contact. DIN 72552 specifies the numbering. https://en.wikipedia.org/wiki/DIN_72552 (which is not entirely consistent with what is actually being used, see first comment below)
Here is a link to an adjustable timer relay for automotive type relays.
12V, 10A Adjustable Delay Timer Relay (Delay ON or OFF)
or
https://www.12voltplanet.co.uk/adjustable-delay-timer-relay-delay-on-or-off-12v-10a.html
or
These are special (expensive).
https://www.arc-components.com/0-742-12-durite-12v-adjustable-programmable-timer-relay.html
https://www.arc-components.com/12v-pre-programmed-delay-off-timer-relays.html
