I bought some IRFD9024 p-channel MOSFETs, and for some reason there seems to be a diode drop from the SOURCE to the DRAIN. As far as I understood it, the body diode is from the DRAIN to the SOURCE as illustrated by the datasheet:
To provide some context, here is my complete circuit. It uses a push button to short the capacitor, after which the voltage slowly increases again, providing a chosen amount of time for the regulator to deliver 5V to a microcontroller.
    \$\begingroup\$ Your circuit looks correct, other than the strain on the switch and cap when you push on the switch (I recommend a 100 to 1000 ohm resistor in series with the switch). Double-check that you haven't hooked the part up backwards, and that your supplier hasn't accidentally (or negligently, if it's eBay or some other shady source) supplied you with N-channel FETs. \$\endgroup\$ – TimWescott Dec 9 '18 at 17:58
  • \$\begingroup\$ What is your actual question? The body diode is BETWEEN drain and source. Also can you be clear about which FET you are using? \$\endgroup\$ – Andy aka Dec 9 '18 at 17:59
  • \$\begingroup\$ I have not really worked with P-channel MOSFETs aside from in theory, that's why I'm asking. So my question I suppose is, "am I missing something obvious here?". As for the part, I will upload a picture shortly. I acquired it from my local electronics shop (not sure where they get it from). The datasheet I've posted is the one they used on their website. \$\endgroup\$ – Chris-Al Dec 9 '18 at 18:08
  • \$\begingroup\$ The chip reads: IRFD A6I*RW5 9024. It looks exactly like the one in the datasheet \$\endgroup\$ – Chris-Al Dec 9 '18 at 18:19
  • \$\begingroup\$ What makes you think the body diode is reversed? How does your circuit behave differently than what you expect? \$\endgroup\$ – Elliot Alderson Dec 9 '18 at 18:58
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
