Here I began with Vth making mesh equations :
48-6I1-12(I1+I2)=0
12(I1+I2)+42+8I2=0
With which I get I1=4A & I2=-2A
Then I considered the open circuit part AB to use the 2 mesh currents there which is where I do not understand how to proceed.
For Rth also I am getting an error as well.
  • \$\begingroup\$ I get Rth = 6.667 ohms. What did you get and what was the correct answer listed as? I get Vth(AB) = 32 volts. \$\endgroup\$ – Andy aka Dec 9 '18 at 18:07
  • \$\begingroup\$ Rth given is 4ohms I got about 5.333 though and yeah Vth is correct can you explain how you got the Vth \$\endgroup\$ – The Idiot Dec 9 '18 at 18:11
  • \$\begingroup\$ Yeah, sorry, my mistake Rth is 4 ohms. You don't really need to make mesh equations to solve this. \$\endgroup\$ – Andy aka Dec 9 '18 at 18:13
  • \$\begingroup\$ Could you explain it \$\endgroup\$ – The Idiot Dec 9 '18 at 18:16
Start with this: -
The impedance into the node marked with a red arrow is \$\dfrac{1}{\frac{1}{12}+\frac{1}{6}}\$ = 4 ohms.
And this is in series with another 4 ohms when you look at node B. That makes 8 ohms but, there is a resistor to node C\$^1\$ of 8 ohms. So the total impedance between B and A is: -
\$\dfrac{1}{\frac{1}{8}+\frac{1}{8}}\$ = 4 ohms.
\$^1\$ node C connects to node A when analysing impedances because voltage sources short to zero volts. Can you get the voltage next yourself?
| improve this answer | |
  • \$\begingroup\$ yeah actually I got to the Rth part myself later on still stuck with the voltage though getting it as 28V somehow \$\endgroup\$ – The Idiot Dec 9 '18 at 18:26
  • \$\begingroup\$ Work on the voltage at the junction of the three restores where my arrow points. \$\endgroup\$ – Andy aka Dec 9 '18 at 21:07
