How would I go about converting this Boolean expression so that it would only use NAND gates in its circuit?
A ⋅ ¬B ⋅ ¬D + ¬A ⋅ B ⋅ ¬C ⋅ D
  • \$\begingroup\$ Take deMorgan's on it. \$\endgroup\$ Commented Dec 9, 2018 at 22:17
If your expression was: \$f = ¬A ⋅ ¬B ⋅ C ⋅ D + A ⋅ B ⋅ ¬C\$
$$¬A ⋅ ¬B ⋅ C ⋅ D + A ⋅ B ⋅ ¬C$$ deMorgans: Invert expression, change + to ⋅ and invert terms.
$$\overline {\overline {¬A ⋅ ¬B ⋅ C ⋅ D} ⋅ \overline {A ⋅ B ⋅ ¬C}}$$
All NANDs.
Ok, so you have to apply deMorgan's theorem in order to have only NAND gates. I don't want to solve your expresion but I can give you an example: enter image description here will be enter image description here that will be enter image description here
So you have to invert the expressions and change + (OR) with * (AND) .
