I have a low resistance resistor that I would like to use to measure the current through another circuit, but first I need to accurately determine its resistance. (A Bourns # CSS4J-4026R-1L00F, 4-Terminal Current Sense Resistor, 1 mOhms ±1% 4W, 4026).
Its data sheet says it is 0.001 ohm +/- 1%
A basic setup is to apply a voltage to the resistor, measure the current going through it and the voltage across it, using the set up in the diagram above.
I am having some trouble understanding my current and voltage measurements, and how the probes may effect the circuit.
The first thing is measuring the voltage. If I touch my probes together, I get a reading of 0.02 mV. Is this something I need to offset in my measurement? For instance, if I measure 0.16 mV, should I subtract the 0.02 mV and record the measurement as 0.14 mV?
Secondly, when my power supply is OFF, my multimeter current measurement reads 3.7 mA, so as I vary the current limit, the true measurement is 3.7 mA less than what the power supply indicates. For example, if set to a 200 mA current limit, the multimeter reads 197.3 mA.
The idea is to use one multimeter to verify the current to the resistor, as the power supply reading may not necessarily be accurate. However, as I write this I realise my power supply has an OFF button for the voltage output and for the device itself. When the device is OFF, the current reading is 0 mA, when it is ON, but the output is OFF, the reading it 3.7 mA, and when the output is turned ON (with the current limit 200 mA) the current reading is 197.3 mA.
So I reason that the current reading on the multimeter is probably fine as-is. It is just when the supply is ON, even if the output is off, there is a small current leaking through.
But I am still not sure about the voltage.
Edit The diagram I meant was this, with 2 separate meters one for current one for the voltage across the resistor.
  • 4
    \$\begingroup\$ It is unclear to me if you're doing a proper 4-point measurement, if not measuring like in your schematic can introduce HUGE measurement errors as the resistance you want to measure is MUCH smaller than for example the series resistance of the Current meter. Let alone the resistance of the wires. What you need to do is a 4 point measurement where you create separated connections/wires for the current and the voltage, go read: en.wikipedia.org/wiki/Four-terminal_sensing and: allaboutcircuits.com/textbook/direct-current/chpt-8/… \$\endgroup\$ Dec 10, 2018 at 14:28
    \$\begingroup\$ If you can get a low voltage supply or battery to supply a 50 to 100mV with 50 to 100A drop then your offset errors are reduced. But DMM calbration is important. \$\endgroup\$ Dec 10, 2018 at 14:44
  • \$\begingroup\$ Check the power rating of the resistor is suitable before putting a large current through it, if that is how you end up measuring the resistance. \$\endgroup\$ Dec 10, 2018 at 18:36
    \$\begingroup\$ If the ammeter indicates how much current is passing through the resistance at the time its voltage is being measured, the resistance of the ammeter and battery will be irrelevant provided that they're large enough to limit current to a safe level and not so large that current is too small to produce a decent voltage drop across the device being tested. \$\endgroup\$
    – supercat
    Dec 10, 2018 at 23:39
    \$\begingroup\$ @NickT It's a CSS4J-4026R-1L00F - SMD Current Sense Resistor, 0.001 ohm uk.farnell.com/bourns/css4j-4026r-1l00f/… \$\endgroup\$
    – Dave
    Dec 11, 2018 at 11:57
7
I agree with both of your statements, subtract the 20 µV (or add it, depending on polarity), and use the meter measurement of current directly. You have no way of correcting for a span error on either meter.
When measuring such a low resistance, it's vital to use a 4-wire technique. You will also want to use a relatively high current to minimize errors.
To verify 1 mΩ to within, say, ±0.1% (since the resistor is allegedly ±1%) requires a measurement to within 1 µΩ, meaning you will have to be very careful with the connections. Thermal EMFs can also be a problem, which you can partially mitigate by reversing the polarity and making another measurement.
  • \$\begingroup\$ Is the Wheatstone bridge method also applicable? Just out of interest. \$\endgroup\$
    – Solar Mike
    Dec 10, 2018 at 15:08
    \$\begingroup\$ @SolarMike It's possible to incorporate a 4 terminal measurement into a wheatstone bridge arrangement, but not very useful. A Wheatstone bridge is a solution to a different problem. \$\endgroup\$
    – Neil_UK
    Dec 10, 2018 at 15:10
14
You can't "accurately determine" such a low resistance using household DMMs, which are likely completely lack of any calibration whatsoever. Accuracy class of your household DMMs is way worse than 1%, especially on the sensitive low-voltage range, and all your results will be suspect and useless. Plus you need to control temperature of contacts very carefully and avoid thermal gradients, otherwise thermal EMF will screw all your results.
Instead, you should trust the datasheets (if the manufacturer is reputable), and follow ALL recommendations on how to mount/connect/use this device, including PCB pad shapes/solder technique and configuration of voltage sense traces. A resistor is much simpler device than digital multimeter, so it is easier to believe that the class accuracy (1%) is better sustained in resistor than in multimeter. If anything, you should consider calibrating your DMMs using this resistor, not the other way around.
The datasheet for the part you link (CSS4J-4026) shows the recommended (basically required if you want their 1% accuracy) pad layout.
Notably, it is a 4 terminal resistor and the claims about it being "1 mΩ ± 1%" is only with respect to the voltage out the sense terminals when passing current through the shunt terminals. The resistance across the shunt terminals will be larger.
The model for the resistor as a whole is something like:
I don't think there are any specific guarantees as to the resistance on the leads, other than they're "low", probably no more than 10-100% the resistance of the shunt itself.
