This is probably an easy one for you. In the following circuit
I want to calculate the active and reactive power in load R2-C3. I've calculated the voltage over these elements to be
$$u=\hat{U} \sin(\omega t + \phi) = 0.0465 \sin(1000 t + 3.53 \text{ rad}) V$$
Now I calculate the active power, P, to be
$$P = \frac{U_e^2}{R2}$$
and the reactive power, Q, to be
$$Q = \frac{U_e^2}{\Im (Z_{C3})}$$
Where $$Z_{C3}$$ is the impedance corresponding to C3 and $$U_e = \frac{\hat{U}}{\sqrt{2}}$$ is the effective value, or root mean square, of voltage u.
Am I doing this correctly?
  • \$\begingroup\$ Are you assuming that the phase angle of \$U_e\$ is zero or does it have a reactive component? \$\endgroup\$ Dec 12, 2018 at 16:29
  • \$\begingroup\$ The input power comes from I1 and not a voltage source so how would you calculate the voltage? Plus, there is no statement about the transformer's turns ratio or parasitic components. \$\endgroup\$
    Dec 12, 2018 at 16:33
  • \$\begingroup\$ See my edits. I've already dealt with the transformer and know the voltage over R2-C3. So it was probably confusing, and unnecessary, to include the previous circuit in the question. \$\endgroup\$ Dec 12, 2018 at 16:45
  • \$\begingroup\$ Take the voltage as the zero phase angle reference, then calculate \$U^2/R\$ for the power and \$U^2/X\$ for the reactive VA, where \$U\$ is the RMS value. \$\endgroup\$
    – Chu
    Dec 12, 2018 at 23:17
You are given \$u\$ peak amplitude so let \$U\$ be it's rms value - then simply,
$$P=\frac{U^2}{R}\text{ watts}$$ $$Q=\frac{U^2}{X_C}\text{ vars}$$
$$S=P-jQ$$
The phase angle on the voltage is irrelevant. I agree with Jan's results.
Well, the real power is given by:
$$\text{P}=\text{V}_\text{rms}\text{I}_\text{rms}\cos\left(\varphi\right)\tag1$$
Where \$\varphi=\left|\arg\left(\underline{\text{V}}\right)-\arg\left(\underline{\text{I}}\right)\right|=\left|\arg\left(\underline{\text{Z}}\right)\right|\$.
The complex power is given by:
$$\text{Q}=\text{V}_\text{rms}\text{I}_\text{rms}\sin\left(\varphi\right)\tag2$$
And the apparent power is given by:
$$\text{S}=\sqrt{\text{P}^2+\text{Q}^2}=\text{V}_\text{rms}\text{I}_\text{rms}\tag3$$
So, for your circuit:
  1. Resistor: $$\text{P}=\frac{0.0465}{\sqrt{2}}\cdot\frac{1}{\sqrt{2}}\cdot\frac{0.0465}{8.5\cdot1000}\cdot\cos\left(\left|\arg\left(8.5\cdot1000\right)\right|\right)=$$ $$\frac{0.0465^2}{2\cdot8500}\cdot\cos\left(0\right)\approx0.00000013\space\text{W}\tag4$$
  2. Capacitor: $$\text{Q}=\frac{0.0465}{\sqrt{2}}\cdot\frac{1}{\sqrt{2}}\cdot\frac{0.0465}{\frac{1}{2000\pi\cdot170\cdot10^{-6}}}\cdot\sin\left(\left|\arg\left(\frac{1}{\text{j}\cdot2000\pi\cdot170\cdot10^{-6}}\right)\right|\right)=$$ $$\frac{2000\pi\cdot170\cdot10^{-6}\cdot0.0465^2}{2}\cdot\sin\left(\frac{3\pi}{2}\right)\approx-0.00115479\space\text{VAR}\tag4$$
If the capacitor were a second resistor, you would write
$$P=\frac{U_e^2}{R_{tot}}=\frac{U_e^2}{(R_2\parallel R_3)}=\frac{U_e^2}{\frac{R_2R_3}{R_2+R_3}}$$
Same applies to this complex network:
$$P=\frac{U_e^2}{Z_{tot}}=\frac{U_e^2}{(R_2\parallel Z_{C_3})}$$
So, it's now a little more complicated to get \$\Re(P)\$ and \$\Im(P)\$, but that's just math...
