I'm very new to oscillators but very keen to learn more so I connected this very simple circuit:
where the voltage source is my signal generators and I have an oscilloscope connected across the capacitor.
Here is a picture:
The formula to calculate the resonant frequency is:
$${\displaystyle f_{0}={\frac {\omega _{0}}{2\pi }}={\frac {1}{2\pi {\sqrt {LC}}}}\,.}$$
My inductor has a value of 100uH, and the capacitors is 100uF, so the formula gives the resonant frequency of around 1.6kHz. For a parallel LC circuit, this should give the highest impedance for the circuit, so therefore the voltage reading on the oscilloscope should be the highest at this frequency.
However, this is not what I'm observing. The highest voltage seems to be at around 4.7kHz:
It has about 440mV volt peak to peak (the signal generator is set to 2V) while around the calculated resonant frequency:
The voltage is around 340mV peak to peak, much lower value. For higher voltages than 4.7kHz, the reading is smaller again.
So what am I misunderstanding/doing wrong? I understand that a basic LC circuit is not an ideal filter, but how is the measured resonant frequency so different from the calculated one?
