I have a 5 wire micro jst cable with a line for ADC readings from an IR sensor that is picking up interference from the cellular antenna of the microcontroller. Will I be able to reduce this noise if I use a USB cable with grounded shielding? What is the best way I can reduce this interference noise?
Thank you!
    \$\begingroup\$ Trial and error is the only approach that the limited content of your question allows me to recommend. \$\endgroup\$ – Andy aka Dec 13 '18 at 0:16
Consider this
| improve this answer | |
