Is there a difference between these two ICs, or are they the same?
https://assets.nexperia.com/documents/data-sheet/74HC4049.pdf
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityIs there a difference between these two ICs, or are they the same?
They're two versions of the same standard part made by two different manufacturers (NXP and TI, respectively). Some of the detailed specifications may differ slightly, but generally speaking these parts will be fully interchangeable.
to short answer no.. but if you get into details (look into max temperature) for example. they differ slightly but usually it doesnt matter look at this: EEVblog #1057 - µCurrent Murphy
