I have a ~20 year old Weller station (base: 921ZX-0, iron: 9216, tip: U9960) for which I've lost all but the 9960 tip. Searches for Weller/Ungar 9960 as a starting point for finding compatible tips have proven fruitless. 20-year-old Jensen Tools catalogs are not the sort of thing Google Books ever scanned :)
Which line of modern Weller tips would be compatible with this old beast?
  • \$\begingroup\$ Checked ebay? Lots of « pattern » ones on there... \$\endgroup\$
    – Solar Mike
    Dec 13, 2018 at 6:50
  • \$\begingroup\$ what do you mean "pattern"? \$\endgroup\$
    – JayEye
    Dec 14, 2018 at 19:09
  • \$\begingroup\$ (yes, of course I checked ebay, but i can only check part numbers I know about; I would also need a list of which tips are compatible with the particular iron) \$\endgroup\$
    – JayEye
    Dec 14, 2018 at 19:10
  • \$\begingroup\$ found some for mine - search and find yours... \$\endgroup\$
    – Solar Mike
    Dec 14, 2018 at 19:17
  • \$\begingroup\$ @JayEye A pattern part is an aftermarket version of a part made by a (supposedly) licensed manufacturer. A pattern in this context is a design, perhaps more often heard of as a knitting pattern. \$\endgroup\$ Oct 22, 2019 at 9:04
A bit more searching (and more luck) uncovered this catalog: https://www.audiolabga.com/pdf/UNGAR.pdf. On page 22, I found the list of all compatible tips. Now I can go on ebay and search for the ones I need.
  • \$\begingroup\$ I ordered a couple from ebay and they arrived. They'll probably outlive me :) \$\endgroup\$
    – JayEye
    Jan 4, 2019 at 21:52
