I want to ask, if this circuit will work. I think the flyback from the inductive load the mosfet is connected to will break the optocoupler. The LED is connected through a resistor which should protect it. Also, is the circuit well designed? The inductive loads are 100 Ohms, 28 Ohms, working at 30 volts.
    \$\begingroup\$ That's a PCB layout and not a circuit. Post a circuit diagram with part numbers. \$\endgroup\$ – Andy aka Dec 13 '18 at 9:49
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
