I'm trying to connect the Arduino Lilypad USB to a MicroSD breakout board. I'm unsure which pins to use for the CS, DI, DO and CLK connections on the MicroSD board. enter image description here
  • \$\begingroup\$ do you see the 2x3 holes? solder a header to it. it is an ICSP header with SPI pins \$\endgroup\$
    – Juraj
    Dec 13, 2018 at 14:01
  • \$\begingroup\$ Will the normal Arduino Lilypad ATmega 328p not have this issue? \$\endgroup\$
    – gilianzz
    Dec 13, 2018 at 17:35
  • \$\begingroup\$ what issue? the pins are there. you only need to add the 2x3 header \$\endgroup\$
    – Juraj
    Dec 13, 2018 at 18:22
  • \$\begingroup\$ It won't be suitable for my project, as I want to use e-sewing. \$\endgroup\$
    – gilianzz
    Dec 13, 2018 at 18:24
  • \$\begingroup\$ the solder wires into the holes \$\endgroup\$
    – Juraj
    Dec 13, 2018 at 18:28
