I am trying to implement a hardware timer for STM32F and read the value from it. So far, this is my implementation:
static TIM_HandleTypeDef s_TimerInstance = {.Instance = TIM7};
void vConfigureTimerForRunTimeStats()
  __TIM7_CLK_ENABLE();;
  HAL_TIM_Base_Start(&s_TimerInstance);
  while (true)
      __HAL_TIM_GET_COUNTER(&s_TimerInstance);
      delay(100);
I am getting the following error:
Field '__HAL_TIM_GET_COUNTER(&s_TimerInstance)' could not be
resolved
Can anyone help me out on this?
  • \$\begingroup\$ Can you trace back where the field above is defined? \$\endgroup\$
    – Long Pham
    Dec 13 '18 at 15:33
  • \$\begingroup\$ tracing back takes me to stm32f0xx_hal_tim.h header file, which is included in my include \$\endgroup\$
    – Nil
    Dec 13 '18 at 15:35
    \$\begingroup\$ When you ask about a particular function in a library, it would be very helpful if you provided a link to that library. \$\endgroup\$
    – user103380
    Dec 13 '18 at 15:52
#define __HAL_TIM_GET_COUNTER(__HANDLE__) \
   ((__HANDLE__)->Instance->CNT)
Above is defined in stmf32f0xx_hal_tim.h, which is probably not enabled or included.
Fix that, or use TIM7->CNT.
