I am looking for capacitor type which has very low leakage such as 0.5nA since I am working with a sensor which generates between 0.9nA to 0.55uA.
Based on my research Film or foil Capacitor has the lowest leakage but not even close what I looking for, they all close to micro and not nano.
Note: the cable lenght is 20ft not 200 sorry
    \$\begingroup\$ What range of capacitance are you looking for? \$\endgroup\$
    – Dave Tweed
    Dec 13, 2018 at 21:10
    \$\begingroup\$ What is your circuit configuration? \$\endgroup\$
    Dec 13, 2018 at 21:37
    \$\begingroup\$ Leakage depends on applied Vdc . What is your spec? \$\endgroup\$ Dec 13, 2018 at 21:52
    \$\begingroup\$ @Shahreza are you aware if charge currents from vibration and modulation of dielectric capacitance V=Q/C with a fixed charge, These piezo effects can occur near DC. Is this why you need a cap? \$\endgroup\$ Dec 13, 2018 at 22:44
    \$\begingroup\$ @Shahreza It is not clear why you ask for a low leakage cap that only blocks DC to 1/RC assuming R is feedback R and you have 2 ground symbols ( any more elsewhere?). Pls clarify what your noise spectrum is and how you measured it and the source. Then include lowest signal spectrum. AS it is, it looks like an XY question. ( asking for X when you need Y) Is there is 0Vdc across cap? Yourproblem may be simply Iio and mismatched R inputs \$\endgroup\$ Dec 13, 2018 at 23:52
6
Film cap or NP0 ceramics are good. For example the film Panasonic ECQ-E series has >9000M\$\Omega\$ insulation resistance at 20°C for <= 0.33uF. That's about 0.5nA maximum guaranteed.
A 0.33uF NP0 Kemet C2220C334J1GACTU has 1000M\$\Omega\$-uF or 100G\$\Omega\$ so it would be 3000M\$\Omega\$ worst case at 25°C, so about 3x worse than the film part.
Comparing those two series, the ceramic is better for capacitances less than about 0.1uF, which is where NP0 capacitors start to get expensive anyway.
Both types need some care with mounting to keep the leakage low. Ceramic caps can get micro-cracks which result in excessive leakage and SMT film caps are also prone to damage from the soldering process (through-hole much less so).
If you want to go nuts, there are PTFE (Teflon®) capacitors that are much (maybe 1000x) better, but harder to source and much more expensive.
Edit: Given your 2.2uF requirement, I would suggest the film type. Do consider the time required at 900pA to charge 2.2uF to, say, 1V will be more than 30 minutes. Also, if your diagram says 200 feet, you are going to have to worry (a lot) about the leakage in the cable.. in such a case one would strongly wish to have the amplifier at the other end of the cable if at all possible. Also if there is significant voltage across the caps, even a small change in capacitance (due to temperature or physical changes such as pressure or stress) will result in a significant "noise" current.
  • \$\begingroup\$ Thanks for the respond I meant 20ft not 200 \$\endgroup\$
    – Shahreza
    Dec 13, 2018 at 22:29
  • \$\begingroup\$ Still.. that's a lot of cable. 20mm would be better. \$\endgroup\$ Dec 13, 2018 at 22:30
In my experience any standard ceramic capacitor will be good enough. For example, I have measured a 100pF NP0 capacitor having <10fA of leakage with a 2V bias.
You probably won't get a good result with electrolytics though.
Also beware of the dielectric absorption of any capacitor at low frequency. Even when driven from a low impedance, small currents (significant compared to the currents you are trying to measure) continue to flow in most capacitor types for many 10s of seconds after a change in the applied voltage. Dielectric Absorption
  • \$\begingroup\$ thanks, was not aware of this. Per your link, would it favor poly film over C0G/NP0 then? \$\endgroup\$
    – Pete W
    Jan 11, 2021 at 13:18
