This question is an exact duplicate of:
Well I need to design three stage amplifier The Stages of Amplifier
Im stuck on the output stage, I need that the AC Current on the load will between 20mA to 100mA, but Top current I get is almost 5mA, cant over pass it with use of 12V Vcc. What im Missing?
The original circuit
The current output
EDIT: Redesigned it and now Im gettin 40mA. Thanks for the HELP GUYS!
Curcuit after redesign
Ac current
My mistake, putting too large load.
marked as duplicate by Dave Tweed Jan 2 at 15:33
This question was marked as an exact duplicate of an existing question.
  • \$\begingroup\$ Do you know the ohm's law? 6V/1kΩ = 6mA \$\endgroup\$ – G36 Dec 13 '18 at 21:50
  • \$\begingroup\$ Do you recognize that the output is clipping? This indicates your input signal is too large. To get 100ma peak through 1K Ohm load will require a supply voltage of 100V supply and a 100V peak to peak input signal. Or you could drop the load to 120 Ohms and get 100mA peak. \$\endgroup\$ – Jack Creasey Dec 13 '18 at 22:09
  • \$\begingroup\$ Yeah. my mistake, thanks for the help! \$\endgroup\$ – KnowledgeSeeker Dec 13 '18 at 23:01
    \$\begingroup\$ Please dont' remove the question when it gets answered; leave the question there and add the additional details afterward, so that someone else with the same problem can see what you were asking. \$\endgroup\$ – Hearth Dec 14 '18 at 0:34
  • \$\begingroup\$ Please realize that by editing your figures, you make it impossible to figure out what the problem was. In the future, edit your question to add the solution rather than replacing the original. \$\endgroup\$ – WhatRoughBeast Dec 14 '18 at 6:04
Are you driving to drive a 1k ohm load with 100 ma? That requires 100 volts. You need to rethink your requirements. The 100 ohm resistors in the output stage alone will drop 10 volts at 100 ma. A 12 volt supply is inadequate for this application.
